Transmission & Drivetrain Gearboxes, Differentials, Clutches
Flywheel dowel pins removal!
Old Aug 3, 2009 | 07:00 AM
LongCarv's Avatar
Icon2 Flywheel dowel pins removal!
I need to resurface my flywheel, BUT I am having problems removing the 3 dowel pins, that align the pressure plate. They are stuck
This guy seems to have luck
1 state:
2 state:
Right now I'm at 1st state for 3 days already - no luck for me
Any ideas how to get them out?
Old Aug 3, 2009 | 02:19 PM
jlude90's Avatar
Default Re: Flywheel dowel pins removal!
Whoever is resurfacing it won't take them out?
Old Aug 3, 2009 | 03:11 PM
vietjdmboi's Avatar
i've had luck by using a visegrip or heat up the pin with a torch and sometimes using a hammer and slightly tapping side to side.
Old Aug 4, 2009 | 12:08 AM
LongCarv's Avatar
I asked at differrent shops and it seems that nobody has a specific tool to take them out
I just grinded them a little and tried to put them out with a screwdriver but no luck.
I will try to heat them up.
What if I just cut them and run without? - I have 240whp.
Old Aug 4, 2009 | 06:23 AM
LongCarv's Avatar
No luck with heating them
I will try with some welding
Old Aug 4, 2009 | 06:31 AM
RHD_BB4T's Avatar
Take your drill chuck off the drill... Clamps the dowel pins with the drill chuck, hook a slide hammer up to the drill chuck... get the idea ?
Old Aug 4, 2009 | 06:39 AM
g230sport's Avatar
yep, the idea with that drill chuck is exactly what the tool i use at work does.
that, or if you can see the pin through the backside of the flywheel, get a punch, and tap them out...
pantherninja
Dec 11, 2011 06:14 PM
stefanne3
Jun 2, 2006 03:27 PM
MOVE OVER
Oct 26, 2005 06:08 AM
93FastLs
Mar 16, 2004 06:46 PM
Kataku2K3
Oct 11, 2002 09:49 AM
