rust on the rear wheel wells. HELP
Old Aug 3, 2009 | 06:25 AM
my Efin SI's Avatar
Icon3 rust on the rear wheel wells. HELP
i have rust on both rear wheel wells, as most EFs do. im just wondering what the best way to clean it up and fix it is. i know that bondo wont get the job done there is too much rust for that.
Old Aug 3, 2009 | 06:45 AM
knightsef-eg's Avatar
Default Re: rust on the rear wheel wells. HELP
either weld and cut new rear wheel arches in or ditch the ef and get a cleaner shell..
try the paint and body section
also post a pic so others can see and give there opinions on how to fix it
Old Aug 3, 2009 | 08:21 AM
dephtone's Avatar
Find a junkyard that is a Fender Vendor retailer. You can get replacement quarter panels for any car through them.
This is the only way it should be done unless you can find another EF with clear rear quarters to cut them out of.
Old Aug 4, 2009 | 12:47 AM
crx22's Avatar
If I were to do it again I would just pick a easy color to paint and use bondo after cuttin the worst of it out...the amount of time I had in mine was way too much. Just paint it every 3-5 years it would be easier. Or save up and take it to someone that will do it and you can get them to do it over when it messes up.
Old Aug 4, 2009 | 06:18 AM
my Efin SI's Avatar
i have a whole other parts car, however i am not experienced in welding or anything like that. i think im just going to have to get it done professionally.
ill get a picture of the rust anyway so you know what im workin with.
Old Aug 4, 2009 | 10:09 AM
killercrx91's Avatar
This to help you out alittle if your goin to fix the rust make shorw that you or an good friend does it. Because on my lasted CRX I had rust on both sides like what you have and I pad $600.00 to get it fixxed... There was nothing but body feller on the hole thing =/. I was 16 at the time and Yes I learned alout form that CRX.
Old Aug 5, 2009 | 05:55 AM
my Efin SI's Avatar
thank you. ill keep that in mind. this car is my first project car, so i really have no idea what im getting myself into.
Jahz
Paint and Body
16
Jul 20, 2013 09:01 AM
KrazoMike
Welding / Fabrication
Oct 24, 2011 04:02 AM
unbelievableEG
May 3, 2006 05:49 AM
You Know I Got SOL!
Jun 26, 2005 08:08 PM
