Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Car vibration problem
Old Aug 2, 2009 | 09:14 PM
joestoryboards's Avatar
New User
Icon2 Car vibration problem
Hi all,
I have an '04 Civic LX, 75,000 miles. For the last two months sometimes when I'm driving and going with the flow of traffic, the car would start to shake between 30-40 mph range, like it's going grids. The vibration would go away if I take my foot off the gas or accelerates. The perplexing thing is it doesn't shake at any other speed. The first mechanic I took it to couldn't duplicate it. The second one felt the shake but couldn't find the cause. I've had the tire pressure checked and tires balanced and rotated. My initial thought is it could be a bad ball joint or CV joint. Any idea of what else might cause this?
Thank you for any advice you can give me.
Old Aug 2, 2009 | 10:59 PM
toyomatt84's Avatar
Sanji
Default Re: Car vibration problem
It could be a wheel bearing that isn't seating properly.
Old Aug 3, 2009 | 07:46 PM
New User
How would I check if the bearings are seating properly?
Thanks in advance...
Old Aug 4, 2009 | 12:23 AM
francis09's Avatar
Wheel Balancing, Radiator Fan broken or not balanced. Those I have experienced car shaking. HTH
oneano
May 22, 2011 02:21 PM
wgbm92
May 21, 2011 02:03 PM
boostEG6
13
Nov 5, 2008 06:00 AM
XstouterX
Jan 8, 2006 07:04 PM
