Abs light
Old Aug 2, 2009 | 08:59 PM
JJtegfan14's Avatar
Default Abs light
so after many months my abs light finally pissed me off enough to do something about it. When i bought the car it was already lit he said it was a bad sensor. But does anyone know how to reset it so it will turn off.
Need some help lmk
Old Aug 2, 2009 | 09:05 PM
eg2jr's Avatar
Default Re: Abs light
same problem here...
Old Aug 2, 2009 | 09:27 PM
ek-g6's Avatar
I just took out the little bulb for the abs light, but if you want to fix it, find out what the code is and then fix the problem.
Old Aug 2, 2009 | 10:57 PM
N9NE14's Avatar
I heard that pulling the yellow plug out of the dash turns off the light.
Old Aug 3, 2009 | 07:26 AM
ahcapone's Avatar
Con someone confirm^^
Old Aug 3, 2009 | 11:45 AM
ILS_09's Avatar
If it's a bad sensor then it probably needs some cleaning.Search the forum.I've seen it posted up many times before.If it bothers you that much then you can just disconnect it or remove the bulb from the back of your cluster if you don't intend to fix it lol.
Old Aug 4, 2009 | 04:12 PM
Joshintegra01's Avatar
New User
Here is what happen to my
https://honda-tech.com/forums/showth...egra+abs+light
Old Aug 5, 2009 | 10:27 AM
JJtegfan14's Avatar
anybody know what to do
zrs6v4
Honda Civic (2006 - 2015)
Jun 2, 2010 08:36 AM
ClarkS40
Mar 21, 2009 11:59 PM
lsturbo*
May 19, 2008 11:58 PM
cyrock
Aug 11, 2005 08:16 AM
JimmieD
Jan 14, 2002 08:02 AM
