could it be a fuel problem? "bogging"
i need some help guys i have had this problem now for a while my engine was just rebuilt its a b18c1 with ctr pistons b16 head setup and anyways everything that needed to be replace after time was ect. but my car died before i got it rebuilt now im back on the the road again it died again it was hot out i had been driving maybe for 20 min and it died on me. After 20 min of waiting it started and i drove home i just replaced the ignition coil took it out for a drive seems to drive fine, but it still bogs like it use to is it not getting enough fuel? too much fuel? why does it bog when i try to acclerate. I have put 350 milles since rebuild so its still not broke in sorry, im just trying to include every variable possible so someone on here can save me and diagnost the problem or give me some ideas THANKS!
Bad fuel pump, is what it seems like. do you hear the whining noise from the pump when its on. I would check fuel pressure to see if its getting enough pressure.
I agree just check your fuel pump.Hopefully you build your car correctly, it's just not just slapping on parts.What ecu u running?Did u check your other parts if its old or anything such as your distributor, alternator, starter, correct timing,etc?Did you run a compression test?Are you running the stock injectors or aftermarket, if so what kind?Did you even consider resetting your ecu after before driving it?Maybe it just needs a tune.
It could be a fuel pressure problem. is there a check engine light? it could be a distributor problem, cus my car used to blog out at like 3800, but then i had a code 9 problem.
yeah it boggs at like over 3k and ever the check engine light comes on every time the car warms up the guy who did the rebuild said it might be a cracked sensor he saw when he took the head off hmm ill check the fuel pressure also it doesnt bog everytime just sometimes
3.point.2
Dec 16, 2006 01:12 PM
MAYHEM
Mar 1, 2005 09:07 PM
