ITR tranny in DA, PROBLEM!
I just put in a ITR cable tranny(LSD) in my DA integra today, I drove around to test it and the tranny makes an almost unnoticible whine, and the whole car vibrates slightly at 2k rpm, but fades away once the rpm increase. Im a Mechanic and it seems to me that the tranny is the problem. It never did this before the install. I need your guys help, thanks
other parts installed:
XTD 6-puck unsprung clutch kit
New OEM flywheel
New tie-rod end (right)
New CV-axle (right)
New OEM flywheel
New CV-axle (right)
Are you sure its not the y1 lsd? Doesnt tend to shake much more with an lsd tranny? My y1 does that, it doesnt grind or pop out, and i;ve had it for a couple years now using centerforce dual friction clutch kit.
as long as all your other work was done properly (ex: mounts all tight, didn't damage c/v joint etc..) then yes it does sound to be caused by the trans. have you noticed any binding? possibly the lsd is taking a dump
Yes everything else was done correctly. When I pull it off gear the vibration goes away. Now my question is what will i need to get that fixed? and how much just in parts?
what do u mean by binding? second gear sychro is bad
Really hard to say w/o hearing/feeling it in person. But I would lean towards a bad input shaft bearing. When they fail they can cause a vibration and/or clicking (similar to that of a bad axle).
It's pretty easy to pull the trans apart and check that bearing.
Im gonna take it back down, the thing was i bought from my co-worker and just put it on which was a bad move. I should took it to my friend to look at it. The axles are fine , no play, and free spins normal (on car lift). My friend works at this place here in Hollywood,Fl called JAPTECH, they only work on hondas, im gonna have him take a look at it.
The clutch kit is for a 94 integra ls (which is the block i have/w p72 head)
90-91 and 92-93 clutches are different. a1, s1, y1, j1 input shaft size is smaller than 92+ b series transmission.
Difference between 90-91 clutch kit and 94 kit is the disk AND the bearing.
Only difference between 92-93 clutch kit and 94 kit is the bearing.
i say find out for sure what you have before you do ANYTHING! big/small spline trans and clutch. maybe u got a small spline trans and a big spline clutch. if so, i wouldn't say anything more..
Originally Posted by turbociv910
my cheap set of CV joints vibrated.
Got OEM ones and went away.
Axles can cause vibration, maybe even noise. But judging by his description it doesn't really sound like his problem.
so by the diameter of the shaft... how many different diameters are there?
and i dont see dude confirming the correct clutch disk. unless u guys r pming on the side.
1) He finally figured out it's a YS1 trans (larger shaft dia)
2) He said he's using a 94+ integra clutch kit.
3) All 92+ b series clutch disks are the same in regard to fitment.
It's the combination of posts. He gave some info about his setup, then I gave info regarding fitment...etc. Read everything and it's a conversation back and forth in which we came to certain conclusions (whether stated explictly or simply confirmed by what both of us were talking about).
