JDM same as USDM Intake Manifold?
Old Aug 2, 2009 | 03:44 PM
shiux's Avatar
Default JDM same as USDM Intake Manifold?
I need an OBD2 GSR manifold to replace my OBD1 manifold. It includes all the sensors.
My question is, will all the sensors bolt up to my OBD2 GSR engine harness? Are they different?
Please give me some insight quick!!
Old Aug 2, 2009 | 04:03 PM
shiux's Avatar
Default Re: JDM same as USDM Intake Manifold?
Please I am bidding on one right now but I dont want to get screwed over like I did when I bought a Canadian GSR harness on accident before!
Old Aug 2, 2009 | 04:17 PM
racebum's Avatar
can't remember if the evap port is there. i know the evap port does not exist on the jdm itr. normally usdm gsr manifolds are only $20 tops. just get one of those
Old Aug 2, 2009 | 04:55 PM
SpEeDyX's Avatar
gsr manifolds are crap i would just spend the money to get a skunk2. But im pretty sure the sensors are different from jdm and usdm
Old Aug 2, 2009 | 05:03 PM
shiux's Avatar
I actually like the GSR manifold. More TQ and available throttle response then a Skunk2. (I've used both)
I like the feeling of the GSR IM mated to my B20b =]
Besides, I am really in it just for all the OBD2 sensors.
Old Aug 2, 2009 | 06:15 PM
GSaura's Avatar
The JDM and USDM manifolds are slightly different. There are no holes to bolt the EVAP purge solenoid to on the top of the JDM manifold. The other major difference is that the vacuum nipple on the JDM manifold and the port on the EVAP solenoid are different sizes so you'd have to use adaptors to build a hose between the two, and the purge solenoid might not see enough vacuum (although I don't know for sure). Find a USDM one if you can. It's much simpler. All of the sensors on the JDM manifold will work with your harness, though.
nokturnal_munkeeboy
Feb 2, 2011 01:49 PM
dacaveman
Sep 3, 2004 10:36 PM
blacura
Jun 24, 2004 02:14 PM
esoterEK..
Mar 19, 2004 12:18 AM
MOTOR R
Nov 26, 2001 12:17 PM
