what do these wires do?
they are by the driver side headlights.
http://i140.photobucket.com/albums/r...9/IMG_0370.jpg
http://i140.photobucket.com/albums/r...9/IMG_0371.jpg
they are green/black w/2 silver dots, and black with 2 silver dots.
thanks
also need help with my headlights. my low beams don't work but my high beams do. i am not getting 12v signal to the power(?) wire, the red/ylw 2 black dot wire.
http://i140.photobucket.com/albums/r...9/IMG_0368.jpg
http://i140.photobucket.com/albums/r...9/IMG_0369.jpg
i know they go into the car but i cant see where they go once they enter the firewall.
thanks
thanks
thanks
Last edited by willskillz805; Aug 2, 2009 at 03:48 PM. Reason: for got to add 2 question
i dont have the washer pump in so it might be. the 2 wires are spliced into 2 speaker wires or somethin.
http://i140.photobucket.com/albums/r...9/IMG_0372.jpg
and then they go to this thing
http://i140.photobucket.com/albums/r...9/IMG_0373.jpg
which i think is the horn. but seeing as my horn dont work i dont know
those are the wires that are used to adjust timing. plug in a wire, paper clips or something like that and loop it from one end to the other. in 90+ honda's they are under the dashboard on hte passenger side. and on 90+ you jump it and you CEL flashes on your dashboard like on your ecu
as for the headlights your lucky i had the same problem with my crx 1hr 30min ago. the wires for the driver side are located in the loom that goes over the shock tower. you can tap both low beams to the same wire.
wait do you mean the signal lights? cuz the low beam wires dont work. so what wire would i tap into??
Monty
Sep 3, 2002 06:43 AM
