PA 91 crx tons of parts. mugen+toda_tein 0.o
Old Aug 2, 2009 | 03:24 PM
conceptEG's Avatar
Default 91 crx tons of parts. mugen+toda_tein 0.o
Here are the specs of what I have in the car:
B16A SiR II in 91' CR-X Si
-Exterior-
JDM SiR Conversion all lights
Genuine Mugen Pro.Kit 2 SiR Front Bumper/Rear Bumper/Wing
ViS SiR CF Hood
CATZ MSC Lights
Mugen RG 16 inch Wheels....IM KEEPING
Yokohama Paradas
-Chassis/Suspension-
TEIN Super Street Damper/Pillowball Mounts/EDFC/Bonnet Damper
Mugen Rear Swaybar
Upper Front, upper/lower rear strut bar
Fastbrakes 11" brake upgrade kit
Nissin 15/16 Master Cylinder
-Interior-
Mugen Shift ****
Mugen pedals and custom drilled dead pedal to match mugen pedals
Tenzo short shifter
JDM Rear seat
Bride BrixII seats
-Engine-
Toda Spec B Camshafts....IM KEEPING BUT CAN BE SOLD..
Toda Gen. 2 Gears KEEPING BUT CAN BE SOLD
Toda timing belt
Toda Oil pump gear
Toda valve springs
Supertech high comp. valves
B18C5 Oil Pump
PCTX Pistons
B16A oil cooler
ARP head studs..BENT AND REMOVED
Mugen Headgasket/Thermostat/Thermoswitch
Skunk2 IM/68mm TB/Hondata IM Gasket
A'PEXi VAFCII/Power Intake
B&M FPR
JDM P30 ECU
HKS Sports catback
HKS 4-2-1 two piece Header
-Transmission-
J1 Cable Tranny
Exedy Sports clutch/organic disc
Toda flywheel
now... the b16a is blown. trans is still good. i just cant find the time to get it fixed. 1st gen b16a will fix it.. again im a father of 2 and its just too much for me to deal with right now.
best offer.. no less then 2500.. the suspension is spanking new.. bride seats are in good ondition. heres pics.
http://i161.photobucket.com/albums/t...2007/crx3e.jpg
http://i161.photobucket.com/albums/t...stillincar.jpg
http://i161.photobucket.com/albums/t...e2007/crx2.jpg
http://i161.photobucket.com/albums/t...2007/crx-2.jpg
heres the cams and cam gears. sold seperate from car.. id include the valve springs and retainers for 700 for cams,cam gears,valve springs and retainers.. cams are 5 months old. toda spec b's
also has hasport b series ac adapter.
low ballers will be ignored. i can send more pics when needed. NO RUST!!!!
thanks
Old Aug 16, 2009 | 12:58 PM
known's Avatar
Default Re: 91 crx tons of parts. mugen+toda_tein 0.o
pm'd
Old Aug 16, 2009 | 01:59 PM
ALLBEAST91DA6's Avatar
bump
IntegraMitja
Dec 24, 2009 10:31 PM
Stripped Honda
Apr 24, 2007 10:23 PM
kur0ryu
Jul 26, 2004 09:44 PM
Engo
Jan 8, 2003 04:17 AM
