bored at work = RAM AIR!!!
Old Aug 24, 2002 | 11:15 AM
Boostless97Lude
Guest
Posts: n/a
Default bored at work = RAM AIR!!!
i work at my dad's hardware store and we are usually pretty slow on saturdays, so i got this crazy idea in my head this moring so i went to work on it. it was really easy b/c i had all the supplies i needed right there.
i've seen other Integra's with ram air, but most of them had BOTH lights on passenger side removed
here's a little closer view..... i put Nascar style grill screen over the opening to block out large debris
heres and even closer view.... if you look closely you can see the green foam rubber air filter (lawn mower filter)
under the hood.... the filter is inside the black reducer coupling with some more of that grill mesh there to keep it from sucking the filter itself in
let me know what you guys think
[Modified by Boosted97Lude, 3:27 PM 8/24/2002]
Old Aug 24, 2002 | 11:39 AM
o.G.A.g.'s Avatar
Default Re: bored at work = RAM AIR!!! (Boosted97Lude)
cool idea but damn, get a paint job! hehe
Old Aug 24, 2002 | 11:41 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: bored at work = RAM AIR!!! (Kb8)
hahahaha..... yeah, when i bought the car the paint was coming off the front, but i can't afford the downtime right now... auto-x season and all
Old Aug 24, 2002 | 11:42 AM
ezark's Avatar
that should help quite some.
Old Aug 24, 2002 | 11:45 AM
jeebusm3's Avatar
Default Re: bored at work = RAM AIR!!! (gsR-T mode)
is the lawnmower filter restrictive?
Old Aug 24, 2002 | 11:49 AM
FORCED FED TEG's Avatar
New User
I have a similiar set up on my car. I have a turbo so tube is coming from the side with a K&N cone style filter on it then I built box around it. I'm thinking of taking out the driver side hibeam and puting a oil cooler there.
Old Aug 24, 2002 | 11:50 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: bored at work = RAM AIR!!! (gtravsr)
i wouldn't think so..... it's the foam rubber kind, but like i said, i kind of came up with the idea today at work, so i used what i had access to. i will probably try to come up with something a little better on down the road, once i take it for a good test run
[Modified by Boosted97Lude, 3:52 PM 8/24/2002]
Old Aug 24, 2002 | 12:43 PM
bullz's Avatar
You have a B16?
Old Aug 24, 2002 | 12:51 PM
LuderCriS's Avatar
Default Re: bored at work = RAM AIR!!! (iLLestjr)
dang that looks weird. nice job btw
Old Aug 24, 2002 | 12:52 PM
LuderCriS's Avatar
Default Re: bored at work = RAM AIR!!! (chanluder)
oh yeah u need a paint job ehehe
Old Aug 24, 2002 | 12:57 PM
Mase's Avatar
hey i hope you dont plan on driving that car in the rain, lol
Old Aug 24, 2002 | 02:09 PM
Jesse H's Avatar
You have a B16?
either that or a skunk manifold
Old Aug 24, 2002 | 02:21 PM
uNF$@#!'s Avatar
upside down Acura badge?
Old Aug 24, 2002 | 02:40 PM
Boostless97Lude
Guest
Posts: n/a
You have a B16?
B18B block
JDM B16 Head
Skunk 2 intake maniold
and coming soon... Spoon Sports 70mm throttle body
Boostless97Lude
Guest
Posts: n/a
Default Re: bored at work = RAM AIR!!! (Soup ****)
pisses of the local ricers
Old Aug 24, 2002 | 05:28 PM
MrBite's Avatar
I wouldn't think it's the material that's restrictive, rather, the fact that there is so little of it. Every filter I've ever seen for a 'teg is like 10x the surface area of what you have in there. The flow per square inch probably isn't bad, but you don't have too many square inches Maybe your test drive will prove me wrong, but I'd suggest having that red pipe lead right into the stock air box (bottom covered up somehow).
Old Aug 24, 2002 | 06:40 PM
Understeer's Avatar
Default Re: bored at work = RAM AIR!!! (MrBite)
What do use at night for lights? Drive with one headlight?
Old Aug 24, 2002 | 08:25 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: bored at work = RAM AIR!!! (Fj)
dude... there ARE pics you know..... it's only the highbeam on the the passenger side that is missing, the lights still work good though, even the one high beam i still have works very well, i can hardly tell a difference
Old Aug 24, 2002 | 08:32 PM
Boostless97Lude
Guest
Posts: n/a
ok, i did my test run ont this thing AND.....
i noticed an increase of airflow, and power. the air flow is really strong, i had a friend that stuck his hand up to it to see if he could feel it, and i sucked a paper napkin right out of his other hand. the problem i am seeing so far is that my VTEC is no longer audible... it wasn't very audible in the first place though since i am using a GS-R ecu. the only thing i can think if is if maybe i am not getting enough fuel now to copensate for for the added airflow... i am still running a stock LS fuel setup (fuel pump, pressure regulator, injectors etc), or perhaps the air is actually more restricted now... as you noticed from the pics, i am also using a JDM B16 exhaust manifold, so i wonder if perhaps that too is restricting the flow b/c it has nowhere for it to go. any more opinions on this would be greatful...
this whole thing was done on a whim and i am kinda doing the R&D as i go along, so input would be excellent
rawkus
11
Nov 1, 2007 10:39 AM
ZygSpeed
Acura TSX
Oct 20, 2006 05:57 AM
**DOHC HaTcH**
Feb 14, 2006 06:56 AM
traumatized
May 31, 2004 10:40 AM
Boostless97Lude
Aug 24, 2002 02:42 PM
