FS: K-Series, Civic and Drag Parts, Weld Magnums, DTR Header, Always Updated!
I will ship after payment is received. I will ship USPS Priority Mail for smaller items and FedEx ground for larger items. I will also include a tracking number or delivery confirmation number. Shipped price are for shipping to the 48 States.
I accept money orders, Paypal, and also pickup in Central NJ.
I have many references and vouches H-T, just ask around or I can send you a list.
Contact Info
E-Mail – BigTeggie@gmail.com
PayPal - BigTeggie@gmail.com
Please Email as my PM’s fill up quickly
Please click on the thumbnails for larger images
Brian Crower Stage Cams and Valvetrain K20A2/Z3
-All Parts are brand new in the box, only opened to take pictures.
-BC Stage 3 Cams (BC0043)
-BC Spring Retainer kit BC(0040)
$720 Shipped
Type S shifter box, cables, and Karcepts kit
- Great Condition
-Includes instructions, hardware, and template to install.
$380 Shipped
T1 Catch Can
- Great Condition, Brand New, Only installed on the car for mockup
-Designed for my K engine, 2 -16an on the top to the valvecover and -10an return
$215 Shipped
Aeromotive Fuel Sample Valve
- Great Condition
-Installed on the car for mockup only
$55 Shipped
EG Civic Custom Cluster
-Autometer 10k rpm tach, and SW water temp and fuel pressue
-Includes all sensors
-I have a wiring diagram I will include so you can wire it up
-Great working condition
$230 Shipped
EG Front Knuckles with Circuitworx Hubs
-Originally off my 94 VX, no miles on hubs, bearings, and balljoints
-Brand New OEM HONDA wheel bearings and new ball joints
-Circuitworx 36mm Hubs
-ARP extended wheel studs
-Hubs cost me $300, bearings $100, balljoints $80, plus the knuckles themselves and labor to install…
$475 Shipped
RSX Type S Axles
-Great condition, from a 2005 Type S
-I already swapped the inners so the lengths were good for EG w/Hasport mounts
-Bolted right into the circuitworx hubs
Pending
RSX Type S Throwout Bearings
-Used but in great condition
$15 Shipped each
K24 Timing Chain
-Brand new in the plastic
$60 Shipped
K24A2 Timing Chain
-Used, great condition
$35 Shipped
K20A2 Timing Chain
-Used, Great condition
$35 Shipped
K20A2 Coil Packs
-Great condition, from a 2005 RSX Type-S
$50 Shipped
K20A2 Clutch Slave Cylinder
-Brand new, only installed for mockup
-Includes all fittings and -3AN line to run to the master cylinder, fits great
$50 Shipped
K20A2 Water Neck
-Top is tapped for a water pressure sensor and the smaller lines have 1/8npt plugs
$40 Shipped
K20A2 Water Temp Sensors
$15 Shipped Each (middle)
EG/DC/EK Water Temp Sensors (for stock cluster to work)
$10 Shipped Each (right)
K20A2 Map Sensor
-Great condition
$30 Shipped
K20A2 VSS
-Great condition, 05-06 Type
$20 Shipped
K20A2 TDC Cam Sensors
-Great condition
$40 Shipped for both
K24A2 TDC Cam Sensors
-Great condition
K20A2 Vtec Solenoid (left)
$40 Shipped
K20A2 Vtec Solenoid (middle)
$40 Shipped
K20A2 VTC (right)
$40 Shipped
K20A2 Valve Cover
-Works fine, has a good amount of scratches
$60 Shipped
K20A2 Thermostat Housing
-Great condition, Top port is plugged but you can remove it if you need to
-Includes thermostat
$25 Shipped
K24A2 Water Pump Housing
-Great condition
$40 Shipped
K20A2 Timing Chain Side Engine Mount
-Good working condition
$20 Shipped
K20A2 Tensioner
-Good working condition, I have 1 available
$50 Shipped Each
K-Series OEM Injector Clips
-Great condition
-I have a few sets
$20 Shipped
K20A2 Valvetrain
- From a 2003 head with 29,000 miles
- Good condition
- Includes retainers, intake valvesprings, and exhaust valvesprings
$50 Shipped
Honda S2000 Radio/CD Player
-Lights up amber
-The code is printed on the top
$65 Shipped
Aftermarket RSX Seat Mounts and Slliders
-Selling because I purchased aftermarket seats from a guy with a rsx and I don't have use for them
$125 Shipped
Lucas 440cc High Impedance B,D,H Injectors
-Great working condition, less than 5k miles
-Upgraded to bigger injectors so no use for them
$200 Shipped
TSX Comptech Ice Box
-Used but in great condition, was on my 2005 TSX
-Selling because I went back to stock and am selling my car soon
-Its kinda dirty, but just needs a cleaning
-I have the filter cleaner and oil, just not pictured
$125 Shipped
99-00 Civic SI Radiator
-Great condition
-Includes slim fan
$80 Shipped
SOLD ITEMS
Corbeau Forza Seats
KPRO PNF ECU
Aeromotive Fuel Pressure Regulator
K20A2 Oil Pan
Bosch 1600cc Injectors
Golden Eagle Fuel Rail
Custom 3" EG Hatchback Exhaust
Excessive IM and 75mm Edelbrock TB
Karcepts A/C & P/S Removal Kit
WELD Magnums Front
K24 Crank Pulleys
RLZ Stage 3 B-Series Cams
K24A2 Water Pump and Housing
Jojo EG All Motor Front End
Summit Fuel Pressure Gauge
K20A2 Oil Pump and Chain
Skunk2 Front Control Arms
Full Race EG/EK/DC ProStreet Traction bars
2 Rota Slipstreams with BFG Drag Radials
TSX K24A2 Oil Pan
DTR/SSR K24 4-1 Header w/Megaphone
K20A2 IAT Sensor
RSX Type S Halfshaft
JDM ITR Valvecover
K20A2 Alternator
K20A2 Starter
Weld Magnum Wheels and Slicks
K24 CRV Timing Chain Mount
EG Civic gauge pod with voltmeter and oil pressure
OEM K20A2 Injectors
Omnipower Drag Coilovers EG/DC
Hondata IMG
Brand New Civic SI EP3 Throttle Cable
K20A2 Knock Sensor
Brand New RSX Type S Throwout Bearing
Contact Info
$720 Shipped
- Great Condition
$380 Shipped
T1 Catch Can
$215 Shipped
- Great Condition
$55 Shipped
$230 Shipped
$475 Shipped
RSX Type S Axles
Pending
$15 Shipped each
K24 Timing Chain
$60 Shipped
K24A2 Timing Chain
$35 Shipped
K20A2 Timing Chain
$35 Shipped
K20A2 Coil Packs
$50 Shipped
$50 Shipped
K20A2 Water Neck
$40 Shipped
K20A2 Map Sensor
-Great condition
$30 Shipped
K20A2 VSS
$20 Shipped
-Great condition
-Great condition
$40 Shipped
$40 Shipped
K20A2 VTC (right)
$40 Shipped
K20A2 Valve Cover
$60 Shipped
$25 Shipped
-Great condition
$40 Shipped
$20 Shipped
K20A2 Tensioner
$50 Shipped Each
-Great condition
-I have a few sets
$20 Shipped
K20A2 Valvetrain
- Good condition
$50 Shipped
-Lights up amber
$65 Shipped
$125 Shipped
$200 Shipped
$125 Shipped
-Great condition
-Includes slim fan
$80 Shipped
SOLD ITEMS
Corbeau Forza Seats
KPRO PNF ECU
K20A2 Oil Pan
WELD Magnums Front
K24 Crank Pulleys
TSX K24A2 Oil Pan
K20A2 IAT Sensor
JDM ITR Valvecover
K20A2 Alternator
K20A2 Starter
OEM K20A2 Injectors
Hondata IMG
K20A2 Knock Sensor
