a6 Head on Z6 Block ?'s & help
Old Aug 2, 2009 | 09:45 AM
Hektor's Avatar
Default a6 Head on Z6 Block ?'s & help
Whats up everbody
iam in need of help and knowledge.
I have a D16a6 Engine with bad rings and I have a D16z6 with a messed up head. I wanted to know if it was possible if i swapped the a6 head on the z6 block and if anybody has a how to on doing it?. I just want the car to be drivable since i use it for work.
Old Aug 2, 2009 | 10:00 AM
DCRB's Avatar
Default Re: a6 Head on Z6 Block ?'s & help
you can do it but it would have really low compression... zeals compression calculator says you'd have like 8.6 to one... perfect for a small boost aplication!
although you may have better luck finding a new head for your z6 at the j/y
Old Aug 2, 2009 | 10:27 AM
Hektor's Avatar
What kinda timing belt and other parts would i need to make this work? (head gasket, Head bolts, etc....)
8.6 compression that is low for a a6 head with a z6 bottom end
dc101
Apr 8, 2011 12:42 PM
Beasty91Hatchy
Oct 28, 2010 01:51 AM
_EF9
Jun 19, 2008 05:29 PM
MrCrowley.
Aug 5, 2006 03:51 PM
