Suspension & Brakes Theory, alignment, spring rates....
92 EG6 LCA?
Old Aug 2, 2009 | 08:17 AM
EdSales's Avatar
Default 92 EG6 LCA?
I have a question about LCA's for a 92 EG6. The CX doesn't have Sway Mounting Points, and I heard the Blox LCA's don't have the proper sway bar mounting points, so what LCA should I get to work with a Sub-Frame Brace with a 24MM Sway Bar?
Old Aug 2, 2009 | 06:22 PM
Egezzy's Avatar
Spongebrad Squarepants
Default Re: 92 EG6 LCA?
no it doesnt. for what you just asked. asr combo w function7 lcas will be one popular combo to go with.
Old Aug 2, 2009 | 06:47 PM
STOCK_SOHC_DX's Avatar
If you can find stock OEM 94-01 Integra LCA's this will work also. Thanks for having a brain and doing some research before buying crap LCA's.
Old Aug 2, 2009 | 07:15 PM
kristo's Avatar
Loved
Blox lca's ànd F7 lca's are supposed to use Blox/asr style endlinks. Those tend to rust and ratlle, as the parts are completely exposed.
I would use OEM lca's and endlinks
Last edited by kristo; Aug 2, 2009 at 09:15 PM. Reason: corrected mistake: eg6 lca's = ITR (not)
Old Aug 2, 2009 | 08:57 PM
Egezzy's Avatar
damn shitty internet...or h.t.
ok i did a whole long write up since i have used blox..f7..and itr lcas.
but im too pissed off so im just going to keep this short.
itr lcas are not the same style as oem eh/eg lcas.
there are also 2 types of eh/eg lcas. ones that are compatible with arb and obviously one is not.
i am guessing your suspension is for an oem eh/eg setup. so you can use eh3/8 or ej1...also like it was mentioned before. u can also use 94-01 non itr integra lcas.
Old Aug 2, 2009 | 09:05 PM
kristo's Avatar
Loved
weren't you off to bed
Old Aug 2, 2009 | 09:10 PM
Egezzy's Avatar
lol. that reminds me. zzzZZZZzzZzZZZz!!
Old Aug 2, 2009 | 09:14 PM
kristo's Avatar
Loved
Corrected an apparent mistake in post above.
Old Aug 2, 2009 | 09:17 PM
kristo's Avatar
Loved
@ TS: why do you post this Q if you have a EG6 (with swaybar rlca mounting holes)?
Or don't you?
Old Aug 2, 2009 | 09:21 PM
This is WRONG. Blox are meant to use the adjustable end links because they are designed wrong with crap bushings. You can use OEM end links with Function7 but need longer bolts to mount the stock end links. I am running OEM LCA's on my EK with ITR rear sway bar and Function7 LCA's on my EG1 with OEM GSR sway bar.
Old Aug 2, 2009 | 09:31 PM
kristo's Avatar
Loved
Excuse me but what are you saying here.
I don't see what bushings have to do with the endlinks but please elaborate.
So you are saying you can use the OEM ones but you have to make one bolt longer. That's true but that's not the same as saying you can 'just' use them. You can also cut part of the mounting hole as I'v stated somewhere else.
So I don't see what' so 'WRONG' about my statement.
Shouldn't do that. ITR sway geometry is diff from EK9 sway geometry (it fits, yeah, but that doesn't mean it fits good).
Old Aug 2, 2009 | 09:42 PM
The Blox LCA bushing are crap.
replacing a bolt > buying new end links or even cutting ****.
ITR sway bar on EK civic, you can't be serious.
Old Aug 2, 2009 | 09:48 PM
kristo's Avatar
Loved
Granted. Still don't know what this has to do with endlnks though.
You mean just 'replacing' a bolt on an OEM endlink? How you gonna do that? Where you gonna get the joint, not mentioning actually fitting it? As far as I know you can weld an extra piece of bolt onto it, but otherwise ... ? Please enlighten me.
I totally agree. Then why are you running this setup?
Old Aug 2, 2009 | 09:50 PM
You mean just 'replacing' a bolt on an OEM endlink? How you gonna do that? Where you gonna get the joint, not mentioning actually fitting it? As far as I know you can welg a axtra peice of bolt onto it, but otherwise ... ? Please enlighten me.
Have you even seen what stock OEM GSR end links look like?
There are many out there running ITR bar on EK's.
Old Aug 2, 2009 | 09:58 PM
kristo's Avatar
Loved
You mean EG/ITR endlinks? Hmm, you'r right, I was mixing up with EK endlinks, sorry (need to go to bed).
Cause ASR sells them that way. Many people doing wrong things don't make'm right. If it was all the same then why design the EK9 swaybar different from the ITR ...
Old Aug 2, 2009 | 10:02 PM
I think the only thing I will ask for help from you is, getting me some Heineken Pilsner (brown bottles) shipped back here.
Old Aug 2, 2009 | 10:08 PM
kristo's Avatar
Loved
Heineken is Dutch and sucks (recently it's been bougth by Interbrew which is a Belgian company but that doesn't change a thing)
Get original Belgian beer: pils: Stella; Duvel: 'somewhat' heavier; ...
Besides that I do know my suspension but I got a bit mixed up here ...
Old Aug 3, 2009 | 06:47 AM
EdSales's Avatar
Or don't you?
The CX doesn't have mounting holes.
Old Aug 3, 2009 | 06:53 AM
EdSales's Avatar
Ok, so I got lost with a fwe of you battling back and forth, what LCA's and Endlinks should I used to put a Sway Bar in?
And as stated above, I can't use OEM LCA's due to the point of no sway bar mounting points.
Old Aug 3, 2009 | 07:08 AM
Egezzy's Avatar
go back and read my posts. also i would look at f7 or asr adj endlinks.
Old Aug 3, 2009 | 07:10 AM
Egezzy's Avatar
also if you have a 92-95 cx. it is not an eg6. it is an eh2.
Old Aug 3, 2009 | 08:52 AM
kristo's Avatar
Loved
Discussion and making errors leads to wisdom
You can use:
- OEM EG6 lca with OEM EG6 endlinks
- F7 lca with modified (see posts above) OEM endlink or ASR syle endlink (which I would not recommend due to rusting and rattling)
- stock OEM 94-01 Integra LCA's
STOCK_SOHC_DX and Egezzy please correct/add if I'm wrong somewhere
Also, I read here there's a diff between stock OEM 94-01 Integra LCA's and Integra Type-R lca's (and for that matter with EG6 lca) , what is this diff? Must be a USDM thing?
Old Aug 4, 2009 | 04:28 AM
You can use:
Yes you are correct on all accounts. F7 and SKUNK2 LCA's with oem end links and longer bolts or adjustable end links.
89-95 civic LCA's with sway bar mounting holes and 94-01 integra non ITR. 88 civic, CTR, and ITR LCA's have different shock mounting.
EdSales
Suspension & Brakes
Feb 28, 2010 08:47 AM
EdSales
Aug 2, 2009 08:23 AM
elliotEk
Suspension & Brakes
Jul 15, 2008 07:05 AM
bleedblue94
Suspension & Brakes
13
May 20, 2008 02:31 PM
OEMFBP99SI
Suspension & Brakes
19
Sep 18, 2007 05:01 PM
