question about my engine problem
Old Aug 1, 2009 | 10:35 PM
crist488's Avatar
Default question about my engine problem
i bought a 96 ek with the b16a2 swap in it and a few weeks ago the motor blew so i went and bought a motor and i got a jdm b16a2 sir2 since then the motor has been put in and only thing left to do is to plug in the engine harness and see if it starts ( thats what i was told from the mechanic ) the mechanic has had the car for a while and im starting to think something is wrong........ so is there something that im missing or might need to get to have the car fully start....... im a noob and its my first honda
Old Aug 1, 2009 | 10:37 PM
StayKrafty's Avatar
Default Re: question about my engine problem
Unless I'm missing something, if a mechanic has it, tell him to plug it all up and see if it fires up.
Old Aug 1, 2009 | 10:45 PM
crist488's Avatar
thats what ive been waiting for ... its been like 3 days since he told me dat all he had to do was to plug in the harness
Old Aug 1, 2009 | 10:46 PM
StayKrafty's Avatar
I would call or go up there and see whats up.
Old Aug 1, 2009 | 10:49 PM
crist488's Avatar
U don't think I would need to change anything since the new engine I got is an sir 2
Old Aug 1, 2009 | 10:53 PM
StayKrafty's Avatar
Well if your car was OBD2 then the OBD2 harness will not plug into the new b16a2 motor.
Old Aug 1, 2009 | 10:58 PM
crist488's Avatar
Ok so if he was to run into this problem what do I need to get cuz I've been carless for like a month now and gettin to work is becoming a hassel and I need my car runnin asap
Old Aug 1, 2009 | 11:00 PM
StayKrafty's Avatar
Hmm, as far as I know, run the dizzy and intake mani from the old motor and it should work? Dont hold me to this though. Was your car OBD2 before? Or still OBD1?
Old Aug 1, 2009 | 11:04 PM
crist488's Avatar
Idk cuz when I bought the car it already had the swap and now I'm fixing everything that's messed up with car
Old Aug 1, 2009 | 11:07 PM
StayKrafty's Avatar
Hmm, well to be on the safe side, I would use the dizzy and intake mani from the old motor any way. Everthing else should plug right up.
Old Aug 1, 2009 | 11:08 PM
slowhatchcali's Avatar
if the b16 that was originally swapped when you got the car was running, then the mechanic can use that harness on the new motor just transfer any needed parts(dizzy, injectors, sensors, etc..) onto the new motor and youre good to go.. i would go check up on him if i were you...
Old Aug 1, 2009 | 11:19 PM
crist488's Avatar
K sounds good ima post more info as I get it
battmancjz
Sep 23, 2016 11:53 AM
Ekay
20
Apr 2, 2011 11:09 AM
Namoper
Aug 19, 2008 06:40 AM
WrongWD
Oct 14, 2004 07:35 PM
G U E C O
Nov 14, 2003 06:18 PM
