Leaky Tailights
Old Aug 1, 2009 | 06:09 PM
Loyalty2086's Avatar
Default Leaky Tailights
Does anybody know of a quick and easy way of sealing up the tail lights on a 5th gen prelude without having to buy new gaskets
Old Aug 1, 2009 | 07:28 PM
Unidentified's Avatar
Default Re: Leaky Tailights
silicone sealer?
Old Aug 2, 2009 | 04:30 AM
street_ride14's Avatar
'Euro-Style' Altezza taillights ? ..OEM taillights should not leak. Every now and then you find an OEM taillight that leaks, but thats 1 out of more than 500. To properly seal a taillight you would have to open them up first, if you don't want to do that then buy a new set.
Old Aug 2, 2009 | 05:31 AM
i guess i got the 1 out of 500 do you know where i can find a picture thread on how to do that
Old Aug 2, 2009 | 05:38 AM
you dont need pictures to do this. Stick taillights in oven at 320 degrees for 8 minutes. The reason you want to do this is to melt the existing sealant for ease of seperating back housing from front lens. Then remove all of old sealant, find OEM-grade sealant, apply, place taillights back together, hold them together with c-clamp style tool, use like 6 of them all around taillight to hold closed, stick back in oven at 320 degrees for about 8 minutes, Done. Easier to buy new taillights, but it's your call.
Old Aug 2, 2009 | 08:09 AM
JDM_EK_SiR's Avatar
Does any water get into your trunk in ur car, i had that problem and it would leak down from the tail lights, i made new gaskets and problem solved
Old Aug 2, 2009 | 12:11 PM
Sonicson's Avatar
New User
Go to a craft store and buy some foam sheets. Trace your old gasket onto the new foam sheet and cut it out. You then have a new gasket.
Old Aug 2, 2009 | 01:25 PM
thanks alot guys i am gonna try and go to the store tomorrow and make new gaskets first thats the easier solution first then i rip apart the tailights i just think they are getting water in them through the holes in the back of the lights
klnteg
Mar 26, 2010 09:57 PM
awwsnap
19
Aug 14, 2005 12:35 PM
Bryan-95prelude
Sep 10, 2004 02:11 AM
crewjones
Oct 25, 2001 03:08 PM
Reverend
Oct 24, 2001 03:28 PM
