What goes here?? thanks!!
putting together my GSR and found something where I don't know what goes in it ... pic below ...
what goes in that? sensor? Thanks!!
oil pressure sensor or switch? the switch is the $7-ish part .. the other, more like $50 ...
**for 'light'
http://shop.oreillyauto.com:80/Produ...pe=417&PTSet=A
**for vtec, vtec pressure switch
**for 'light'
haha oh man ... ok here's a better picture of when I first started the build and shows the back better ... I thought #1 was the knock but wasn't sure of #2 ...
so is this the vtec oil pressure sensor? please tell me it's the cheaper of the 2 haha
**for 'light'
**for 'light'
You can see the oil pressure switch plug/boot in this pic at the very bottom, right near the yellow and white wires (not the wires going to it). The knock sensor is the part with the green plug.
Alright, that is an OBD2 block I'm guessing. Unless it's changed from OBD1 (I don't think so), then #1 is the knock sensor (should be a 2-pin sensor w/ 2-wire plug on the harness) and #2 is the oil PRESSURE switch - which has a single metal pin sticking out of it, and a single wire on the harness with a rubber boot that fits over it.
and yes it's an obd2 gsr block ... do you know if the oil pressure sensor is the same on the ls and the gsr? I'm guessing no ... but just wanna make sure. I'm doing my gsr swap (obd2) into my ls (obd1) and was hoping I could take the sensor off the LS and put it on the GSR?
