Rear brakes dragging
Old Aug 1, 2009 | 12:11 PM
kevinm1981's Avatar
Default Rear brakes dragging
I checked the e brake tension and its not pulling. Should I bleed them?
Old Aug 1, 2009 | 02:09 PM
kevinm1981's Avatar
Default Re: Rear brakes dragging
help
Old Aug 1, 2009 | 06:02 PM
Ruben19's Avatar
try bleeding them if that don't help is a bad caliper
Old Aug 1, 2009 | 06:13 PM
thabao's Avatar
Check your slide pins. They might need lube
Old Aug 1, 2009 | 07:30 PM
Ruben19's Avatar
^that too or they might be frozen
Old Aug 3, 2009 | 02:02 PM
kevinm1981's Avatar
I took the car to les scwhab, they quoted me $467 for new brake pads, rotors and calipers. How in the hell could all of those be bad at once? WTF!!!
Old Aug 3, 2009 | 02:09 PM
TunerN00b's Avatar
I paid:
$65 front pads (pair) (Hawk Ceramic)
$45 rear pads (pair) (Hawk Ceramic)
$15.99 front rotor (each) (Autozone Duralast)
$13.99 rear rotor (each) (Autozone Duralast)
That comes up to $170. Rebuilding calipers costs $300?
And pads and rotors are frequently found "bad" at the same time, when a mechanic is reporting their condition to a customer. I especially love when they try to convince me to turn my rotors "For only $20 each", when they cost less than that brand new...
Only issues I've ever had with the rear brakes is the caliper slide pins sticking, and those just need a nice layer of lube applied (that's what she said).
Old Aug 3, 2009 | 02:24 PM
kevinm1981's Avatar
Thanks a bunch. I will check the slide pins.
Corksil
13
Aug 29, 2012 04:03 PM
cmyates007
18
Apr 14, 2012 10:19 PM
Romo Pyro
Nov 15, 2010 05:31 PM
babzog
Honda Civic (2001 - 2005)
May 22, 2008 09:49 PM
Krnbk2
May 28, 2004 12:47 PM
