POWER WINDOW CONVERSION. HELP.. 96 dx with 99-00 si doors..
PLS HELP AND BUMP THIS THREAD .. TY IN ADVANCE..
Need this finished so i can throw it in the paint shop and get it ready.. for school :\.... HELP..
i have complete si doors and putting it on the 96 civic dx..
Will the 99-00 si window motor, window regulator, and switches work with the 96-98 ex door harnesses and floor harnesses.. ?
HELP.. im so frustrated..
can anyone comfirm if i need the regulator, switches, and window motor for my 96-98 ex harnesses.. ?
help..
96-98 ex driver side harnesses fit and everything works except the window.. yes locks work..
96-98 ex PASSENGER side door harnesses was completely off.. Only one plug fit which is the tweeter wire.. HELP... pls..
i have complete 99-00 si doors
i have for the 96-98 ex
1-floor harnesses
2-ex door harnsses(passenger side seem to not have any plug and play)
3- 4-5 20 amp fuses
4- under hood fuse (40 amp)
5- relay (under dash fuse box)
6- door lock control box (blue)
help..
1-floor harnesses
3- 4-5 20 amp fuses
i did this a a couple years ago same car same swap. but i found out u need a lot of stuff to make it work oem. theres a write up for this. but the way i did it was i wired all the windows door locks and tweaters myself. well using a diagram from ht. its alot easier and works well its been 2 years and i have had no problems ill try and find it for u
http://repo.jackmoves.com/v/erik/album106/album206
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/96-98-power-window-conversion-using-99-00-si-door-harnesses-no-floor-harness-1762783/
and heres mine
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/si-doors-96-civic-1865122/
and heres mine
im almost positive you can just use the regulators/locks from the si doors, with the 96-98 ex door harness/floor harness. and if the lock control unit is blue, im assuming its from a 96-98 anyways.
thx.. just got it working. like 2 hrs ago
thx everyone.
i just spliced the blue/black and green/black and connected to the cigarette wire/ac socket .. changed the ac socket fuse to the 20 amp.
everything elses worked plug and play..
but for some reason the passenger 96-98 ex harness didnt fit si doors.. only the tweeters. so i kept the si on the pass.. and ex on the driverside..
thx again ppl.. you guys saved me from giving up on my honda.. ahah.
thx everyone.
ahha ok.. ill sell it to you to $800 and ill include the HIGH FIVE
Thx again man. i want to splice anything but i was so close and i did. :D
junintegra2000
Jul 11, 2008 05:23 PM
310HPS2k
14
Nov 2, 2007 09:02 PM
JLEK
Dec 23, 2006 04:55 AM
dragonjay006
Nov 8, 2006 01:01 PM
kidd_drastic
May 1, 2006 05:34 PM
