How to replace altenator w/o removing half shaft?
Old Aug 1, 2009 | 10:23 AM
TigerLy's Avatar
Icon2 How to replace altenator w/o removing half shaft?
I have a 93 integra and I was wondering if there was a way to take out the alternator without removing the half shaft and the cv axle..
Old Aug 1, 2009 | 01:11 PM
kchungb17a's Avatar
Default Re: How to replace altenator w/o removing half shaft?
As I recall, if you remove the tire and crank the steering wheel in one of the directions (don't remember which one), you will have enough room to wriggle the alternator out.
Old Aug 1, 2009 | 06:05 PM
Ruben19's Avatar
i unscrewed my master cylinder from the brake booster
Old Aug 2, 2009 | 10:45 AM
TigerLy's Avatar
i will try turning the wheel.. i don't want to take out the master cylinder cuz i don't want to do all that bleeding stuff.. any other ways people have done it?
Old Aug 2, 2009 | 10:49 AM
R@mon's Avatar
tooo easy...... remove intake manifold =P
Old Aug 2, 2009 | 11:54 AM
CleanLikeJdm's Avatar
Hype-R Stalker
I've pulled mine right straight up, you have to find the right angle and a lot of jamming.
You might scrape a little paint doing this, it's a tight fit.
And I've also only done this on 94+ integras.
Old Aug 2, 2009 | 01:26 PM
ek-g6's Avatar
You woud need to unbolt the halfshaft, and push it to the left, you should be able to push it 2 inches or so, and then thats where you would need spend some time wedging and angling the alternator to get it out.
Old Aug 2, 2009 | 02:10 PM
TypeRMOBBiN209's Avatar
i unbolted the alternator and got it by moving it around in the back of the motor under the manifold...you just gotta move the hoses out of the way by hand and take off the intake
Old Aug 2, 2009 | 04:00 PM
TigerLy's Avatar
yeah i tried that a few days ago and everytime i got the hoses out the way i dropped the alternator.. i'll try a few more things when i have time and if not i'll just got buy the axle socket is it a 30mm or 32mm?
Old Aug 2, 2009 | 04:51 PM
slaminsam's Avatar
You dont have to bleed your brakes by just unbolting it from the brake booster. It will move enough to get the alternator out.
Old Aug 2, 2009 | 05:58 PM
follie gatts's Avatar
32mm
Old Aug 2, 2009 | 08:32 PM
IN VTEC's Avatar
I think I was able to do it by removing the oil filter and wiggling it out past the intermediate shaft.
rivoe302er
Jun 17, 2008 07:20 AM
jeddy0120
Nov 8, 2007 06:55 PM
trianglegreg
12
Feb 6, 2007 06:31 AM
benvroom
Aug 9, 2005 07:33 AM
'88civic
Nov 3, 2002 06:51 AM
