Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
01 3.2 CL T-Belt write up?
Old Aug 1, 2009 | 10:18 AM
wwcrxww's Avatar
Icon2 01 3.2 CL T-Belt write up?
whats up honda-tech... im doing a timing belt and water pump next weekend on my mothers 01 3.2 CL. Any write ups on this? Or anyone that has done this job have any pointers? Ive never done a t-belt on this particular model and it doesnt look to bad but i figured ill ask for any advice! A descriptive write up including pictures would be great! I want to avoid purchasing the clymers or haynes manual. Thanks again!!!!
Old Aug 1, 2009 | 07:59 PM
wwcrxww's Avatar
Default Re: T-Belt write up?
nineteen views n no one?
Old Aug 1, 2009 | 08:05 PM
Accord tuner's Avatar
just a thought...
maybe if you would have described what you were workin on i the topic you would have gotten some hits from a few people who are knowledgeable of the topic.
Old Aug 2, 2009 | 06:33 AM
t3am spotlit3's Avatar
i have to say making a tread with a question on how to do thing is really a no no,HT got a search box where you can search for it,try it out it be you best friend google would also be nice
Old Aug 2, 2009 | 07:12 AM
wwcrxww's Avatar
ok i see... thanks
Old Aug 3, 2009 | 01:43 AM
YeuEmMaiMai's Avatar
Default Re: 01 3.2 CL T-Belt write up?
t-belt change should not be that much different from any other J series V6 so the accord instructions might get you by
Old Aug 3, 2009 | 04:43 PM
LBizBoy's Avatar
only difference between the 3.0 and 3.2's is the tensioners really.
Old Aug 3, 2009 | 04:59 PM
bryse68's Avatar
i think you would not be able to perform this at home unless you have a 3/4 impact gun. and if that good luck breaking the crank bolt.
Old Aug 3, 2009 | 05:03 PM
bryse68's Avatar
from my personal experiences, breaking the crank bolt is the hardest part, i use the crank pulley holder wedged against the subframe, 1/2 breaker bar and a pipe on the breaker bar with the vehicle on a lift. the rest is easy, you can take off the passenger motor mount with out supporting the motor to give you more room.
01accordsauce
Jun 1, 2018 11:29 AM
zacharee
Sep 17, 2010 06:06 PM
cmc600rr
Jul 8, 2010 01:42 AM
hometheaterman
Jun 7, 2010 05:13 AM
904d
Jul 22, 2009 05:44 PM
