Transmission & Drivetrain Gearboxes, Differentials, Clutches
GSR hydro case fits on b16 hydro trans?
Old Aug 1, 2009 | 07:19 AM
Jintegragsr97's Avatar
Default GSR hydro case fits on b16 hydro trans?
My b16 hydro trans case is cracked and leaking badly because my friend dropped it So I was wondering if a GSR case would fit on the b16 trans. If not then I can just put the b16 gears into the Gsr trans right?
Old Aug 1, 2009 | 09:57 AM
92_VX_EG's Avatar
Default Re: GSR hydro case fits on b16 hydro trans?
The hydro cases are all interchangable. If it's the bellhousing that you're changing make sure to take the cups for the open bearing diff out before putting the B16 diff in(it has closed bearings).
Old Aug 1, 2009 | 01:59 PM
Honda Bull's Avatar
Do as stated above. Also check mainshaft and diff bearing clearance since they are pretty quick and easy to do. Two shims, if needed, only cost $15-20. Cheap insurance.
Old Aug 1, 2009 | 06:53 PM
Cool, Thanks a Lot guys! So If I just change the case then I dont have to change anything else right?
Old Sep 10, 2009 | 09:18 PM
Aquafina's Avatar
Mainshaft needs to be shimmed. Just putting it in and making sure it spins doesn't work.
dc4teg95
Oct 24, 2012 04:54 PM
Jintegragsr97
Jun 3, 2009 12:34 PM
Kyosho26
Oct 5, 2005 03:35 PM
