so i want to start tuning.....what do i need?
Old Aug 1, 2009 | 03:55 AM
d16z6Tcrx's Avatar
Default so i want to start tuning.....what do i need?
i have s300 on my personal car which works flawlessly. but i want to start street tuning acouple of my buddies cars. what exactly would i need as far as like a chip burner and what not. i also want to be able to datalog in realtime if thats possible.
1. chip burner
2.
3.
4.
5.
also best brands and websites to order from whould be good. thanks
Old Aug 1, 2009 | 05:54 AM
i drive a honda's Avatar
Default Re: so i want to start tuning.....what do i need?
1. chip burner
2.
3.
4.
5.
don't need a eeprom chip burner for an s300, that is the whole point of spending the extra money on the hondata unit , simple map editing, and seamless reliable transmissions onto your EMS.
Old Aug 1, 2009 | 06:10 AM
d16z6Tcrx's Avatar
obviously you are not underststanding what i meant so ill help you.
i have s300 on my car tuned and ready to run.
i want to tune my buddies car on a system that uses a eeprom. Not my s300. what do i need to do it fully.
Old Aug 1, 2009 | 07:10 AM
bigD's Avatar
http://www.xenocron.com/dyno-tuning-...e199348ab1c54e
Old Aug 1, 2009 | 08:20 AM
d16z6Tcrx's Avatar
thanks. now it has the add on option for ectune pro. if i bought that will i be able to tune other cars on ectune or just one?
Old Aug 1, 2009 | 08:47 AM
HRTuning's Avatar
Just one. You'd need to get in touch with the eCtune guys to get setup as a dealer.
Old Aug 1, 2009 | 09:01 AM
h46it's Avatar
1. chip burner
2.
3.
4.
5.
1. chip burner
2. crome/ectune/neptune
What you could do is use your s300 to tune your friends cars and copy the map to crome/ectune/neptune and burn a rom from there.
Old Aug 1, 2009 | 09:07 AM
Turbogixxer's Avatar
Originally Posted by h46it
1. chip burner
You can not copy s300 maps into crome/ectune/neptune
Old Aug 1, 2009 | 09:09 AM
d16z6Tcrx's Avatar
ok well ill just use the crome pro than thanks.
Old Aug 1, 2009 | 12:34 PM
my bad, so old school stuff?
chipable ECU
stack of 28 pin eeproms, opensource or freeware map editing soft wares, your current maps won't work, ostrich, soldering iron, solder sucker (alot of people hack off the backhalf of the solder suckers and tape them to a vacuum for ease of use when doing this ****), it is a good idea to get a few extra ZIF sockets in case they break and they are cheap.
Old Aug 1, 2009 | 12:45 PM
d16z6Tcrx's Avatar
thanks
Old Aug 2, 2009 | 07:45 AM
h46it's Avatar
You can copy and paste the values from S300 to Crome. Works but you will have to change rpm values if they are different.
Old Aug 2, 2009 | 10:50 PM
teamjdm239's Avatar
a chip burner,a wideband, a emulator, a datalogger, and a chip kit if he doesnt have a vtec/chipped ecu.
Old Aug 3, 2009 | 08:06 AM
HRTuning's Avatar
No, you can't. Different code bases so it will not run the same even with the same values. You'll need to tune it out after doing so.
Old Aug 3, 2009 | 09:07 AM
h46it's Avatar
I'm going to give this a try.
Old Aug 3, 2009 | 10:16 AM
h46it's Avatar
Well it works from copying from Hondata s300 to pasted into Crome.
I did a simple copy and paste values from a stock p28(pasted into p30 base code in crome). If you look at the rom from Hondata all values are higher than what's in Crome(Looks to be about 20% higher). Tried it in my car, rom works with no CEL and runs.
So yes you can copy and paste, but as HRTuning is saying is the car is not going to run same as looks like fuel values are higher.
Old Aug 3, 2009 | 10:39 AM
HRTuning's Avatar
Oh ya, you can definitely copy/paste between the two, but it just won't run exactly the same even with the same exact values in both.
Old Aug 3, 2009 | 11:02 AM
rschoener's Avatar
I agree. just copying and pasting from one system to another is not good practice.
Yea could you do it and get it close probbl. but you still need to tune on the system you will be putting in the customers car.
bigislandc2
Engine Management and Tuning
Jun 18, 2010 11:35 PM
turbodcxbro
Jan 3, 2010 06:41 AM
crxb16a90
Aug 28, 2009 09:19 AM
Navy_CRX
Jun 19, 2009 08:15 PM
Acura_I-RS
Mar 23, 2003 07:02 AM
