car starts but will not stay on.
ok my car will not start... i stopped the car and got out to get something, the got back in the car, tried to turn it on, the engine started but as soon as i let the key down to drive... the car shuts off. its like there is no power in acc mode. so i dont know what is wrong with it can any one help me out, cuz i have work to go to and i need my car for that.
checked all fuses, back up one is out under to hood, no cel, fuel pump prming i dont know, and i dont wat the main relay even dose...btw that you your post
fuel pump priming is not confirmed. sure somethign clicks two seconds after..but do you actually hear the fuel pump turn on then off?
starts then stall imediatly sounds like fuel issue. or alarm issue but i would suspect fuel first.
I think the ignition switch is bad (bad ON(II) position).
Here's how to test using a multimeter to measure continuity/resistance (Ohms) at the switch connector terminals:
wtfisvtec??
38
Jun 30, 2024 05:13 PM
si90rex
Jun 24, 2007 05:53 PM
white90crxhf
12
Aug 17, 2006 09:16 PM
