99gsr swap into a ef hatch
Old Jul 31, 2009 | 06:29 PM
ZCSp0ngeR's Avatar
Default 99gsr swap into a ef hatch
i swapped a 99gsr in to my car but the main problem is that i am not getting any gas to the engine i even bought a walbro 255 and i converted to obd 1when i turn the key im not getting any power to the pump but i can jump the wires at the sending unit and the pump turns on. i never had any issues before. anyone had this problem before
99gsr block ctr pistons .030 over
99 b16 head
stock p28 for now
obd0-obd1 conversion full plug and play jumper kit
Old Jul 31, 2009 | 09:50 PM
D16SiHatch's Avatar
Default Re: 99gsr swap into a ef hatch
main fuel relay? does it click on and off when you turn the key to ON?
Old Aug 1, 2009 | 04:12 AM
ZCSp0ngeR's Avatar
no i dont hear any clicking
ZCSp0ngeR's Avatar
where is that located main fuel relay?
Old Aug 1, 2009 | 04:17 AM
RamoncilloSI's Avatar
under dash in a corner, driver side.
Old Aug 1, 2009 | 04:24 AM
ZCSp0ngeR's Avatar
is it available at like autozone or dealer/junkyard only
Old Aug 2, 2009 | 07:00 PM
ZCSp0ngeR's Avatar
Ok guys i still need your help i put in a main relay in today and still my pump is not priming i did test before i put it in the tank and everything works fine im stumped. i have checked all fuses and they are also fine
Old Aug 2, 2009 | 07:21 PM
kingcu90's Avatar
funny that u say that i did the same thing to my ef, but i have to tap the relay multiple time then it turn on>>>> dont ask why it douse that but it works for me.........my also does not make a click, i just tap and go ......lol
Old Aug 2, 2009 | 07:29 PM
ZCSp0ngeR's Avatar
i tapped the hell out of it still not working i even swapped it out
Old Aug 2, 2009 | 08:41 PM
ZCSp0ngeR's Avatar
bump for some help
Old Aug 2, 2009 | 08:46 PM
BiG ChOr!Zo's Avatar
just by chance did you buy that walbro fuel pump on ebay...!!!
Old Aug 2, 2009 | 09:33 PM
boostedEF91's Avatar
grounding problem.. do you have all your grounds hooked up on the motor and what not. do you have the 3 main grounds hooked up.
Old Aug 2, 2009 | 09:36 PM
do you have the ground hooked up on the main harness that usually grounds above the thermostat. and from the valve cover to the bay.
Old Aug 2, 2009 | 09:49 PM
ZCSp0ngeR's Avatar
yes the pump i did get from ebay but i tested the pump before i put it in and it is stronger than the oem one was, i have a ground from valve cover to frame and neg cable to tranny and i have another one on the fuel pump a lil black wire ground
Old Aug 2, 2009 | 09:54 PM
http://www.thezcr.com/forums/showthread.php?t=17579
Old Aug 3, 2009 | 08:02 AM
and did you ground the main harness .. it usually gets grounded right above the thermostat.
Old Aug 3, 2009 | 10:47 AM
jdmoptiontune's Avatar
If you do not have the wiring harness bolted to the thermostat housing the car WILL NOT start. Because it is not grounded. We swapped a GSR in my friends ef and he forgot that part.
Old Aug 4, 2009 | 02:29 PM
ZCSp0ngeR's Avatar
i did forget to put the thermostat ground but it still did not start, i also had a broken wire on my round dizzy plug still did not start i tried the kingcu90 method and it started so i had 2 bad main relays bought a new one at autozone and it fired right up thank for the help
Old Aug 4, 2009 | 02:45 PM
crxb16a90's Avatar
what wireharness u using?? and u convert to obd1, are u using obd0 injector(with resistor box) or obd1 without the resistor box. just wonder
Old Aug 4, 2009 | 05:58 PM
djstevehawken's Avatar
Same thing happened to me. I've got an ODB1 LS swap in my 91 hatch.
I replaced Main relay, ECU, distributor , Fuel pump. Nothing worked.. checked all my fuses with a multimeter and it said they were fine. I finally got fed up and replaced every fuse on the entire car ~$50 from autozone and BAM... FUEL AND SPARK.. just my 2 cents.
Old Aug 5, 2009 | 03:44 PM
ZCSp0ngeR's Avatar
i finally got my car started and its running however i think i need to redo my valves because thee is a slight chatter from the valve cover, im also throwing a obd1 code 14
Torres320
11
Aug 25, 2015 12:51 AM
srt4pilot
17
Jun 10, 2009 12:57 PM
wrestler72
Aug 17, 2007 03:38 AM
RenoRacing
Sep 8, 2002 09:41 PM
