Main Relay clicking consistantly?
ok so i have an automatic EG and it was stolen 2 months ago. car has been sitting since. yesterday and today i had tried to start it..
i had hooked up the cables from my sedan to the EG so it gets power. i put a gallon of gas in there as well since it was near empty. the car is on my driveway with the front pointing outward. i did that so the gas would go to the pump??
but anyways, i go ahead and tried to start the car. thing is, the car doesnt have an ignition, its just the white piece that i can stick a flat head and turn, steering wheel is unlock as well.
so i turn 1st click, then second click, the main relay does a consistent clicking noise and i can feel it with my hand on the relay. car cranks over and over but doesnt start. i have car in "P" position and brakes down with throttle half way..
does this mean the relay is out?
try putting the battery directly on the car, or use a jump starter and set it to the "start" position.. that happened to a buddies car a while back and that did it...
slowhatch: what do you mean put in the "on" position if i was to just slap my battery on there..?
jcali: wires look perfectly fine..
my bad.. i meant that if youre going to hooke up a battery charger to it, to switch it to start mode.. but if the battery youre putting is a good battery then just slap it on.
make sure ur engine harness is still wired up... i had the same noise when i hooked up my resistor box and it would click then i looked at the engine harness and the clips werent hooked up by the brake/ clutch master cylinder...give that a shot i bet it will fix your problem
stevew84
25
Jul 17, 2008 06:16 AM
TURBO DC2
Oct 5, 2005 11:18 AM
