Tail light/brake light problem please help!
Old Jul 31, 2009 | 03:43 PM
TGMtypeR's Avatar
Default Tail light/brake light problem please help!
so ive had this 91 civic dx 4 door sitting around for a while and recently got it running because i had to sell my other civic and my DA is in pieces.
I have recently been having brake light and tail light problems due to corroded plugs. I fixed all of that and everything has been fine until last night the brake lights would not light up.
the turn signal lights, reverse lights, and the two brakelight/tail lights DO light up, they just dont get extra bright when i hit the brakes. i checked all the bulbs, all the connections and everything seems fine. what do i look for next?
Old Jul 31, 2009 | 03:49 PM
BiG ChOr!Zo's Avatar
Default Re: Tail light/brake light problem please help!
check wiring and fuses yo
Old Jul 31, 2009 | 04:13 PM
project91crxsi's Avatar
yes check fuses i just had the same problem last night
Old Jul 31, 2009 | 04:27 PM
TGMtypeR's Avatar
im not sure why it would be the fuses since the tail lights DO light up and stay on when i hit the brakes, they just dont get brighter. but yeah i checked the fuses allready and they are all good
Old Jul 31, 2009 | 04:51 PM
idk mine lit up when i hit the breaks but i let off and theyd go off, i replaced the fuse and it worked, but its the same fuse that lights the license plate light so if thats on then its probly not the fuse
Old Jul 31, 2009 | 04:53 PM
try changing the light bulbs...they might be getting weak...!!!
Old Aug 1, 2009 | 06:46 AM
TGMtypeR's Avatar
just did that still no luck HALP!
i double checked all the connections and such and everything looks good.
Old Aug 1, 2009 | 06:51 AM
damn idk then
Old Aug 1, 2009 | 07:58 AM
grog's Avatar
make sure you have the correct dual philiment bulbs. also check the brake light switch, its above the brake pedal. maybe the switch has backed out or gone bad. the switch should be pushed in whe the pedal is "at rest" and it should pop up when pressing it activating the bright philiment in the brake lights. check your grounds and sockets for corrosion (again i know).
David Bromberg
Oct 2, 2012 09:41 AM
toolbox21
Mar 17, 2009 08:31 PM
CrazyRexBoy
Jan 13, 2007 07:14 PM
david90
Dec 9, 2003 04:13 PM
paulyman
Mar 31, 2002 06:56 PM
