Oil In Distributer Problem
Old Jul 31, 2009 | 03:00 PM
97H22Prelude's Avatar
Default Oil In Distributer Problem
Well, i managed to get the motor back together,, it runs perfect and sounds mean like they all do ,,, But when i drive it around and go back home and look the distributer is full of oil and leaking oil too.
Has any1 else gotten the problem and how can i fix it?
I can't go to the track if the car is leaking oil
Old Jul 31, 2009 | 03:08 PM
ludeking1007's Avatar
Default Re: Oil In Distributer Problem
well not to say that you dont know what ur doing but did you put it on wrong
Old Jul 31, 2009 | 03:10 PM
put the distributer on wrong?? there is only 1 way it goes.
kchungb17a's Avatar
If you have oil in your distributor then the rotor shaft seal is leaking. Bad news is you cannot get the seal by itslef, at least not from Honda. Maybe if you know a good seal shop. Otherwise you must buy a new distributor housing. Or if you don't mind aftermarket, you can get a whole new distributor for less.
Old Jul 31, 2009 | 03:11 PM
ya i said that wrong did you have it apart for any rison
Old Jul 31, 2009 | 03:14 PM
ya but if you didint take it apsrt thin thats not it
Old Jul 31, 2009 | 03:20 PM
ok ok, now i have a other distributor but it has internal coil, not external like the one i have and i know u can do a conversion but haven't found a really good tutorial for the conversion yet,,
Old Jul 31, 2009 | 03:44 PM
Apex1972's Avatar
just get something like this, not necessarily from this seller but maybe you get the picture
http://www.1aauto.com/1A/Distributor...ampaign=NexTag
Old Aug 2, 2009 | 05:21 AM
street_ride14's Avatar
Originally Posted by ludeking1007
ya but if you didint take it apart, then thats not it
you have to take apart things in order for them to break ? The seal is internal, built as one with the distributor body and shaft. Seals leak when cycling through many temp changes and getting worn out. To solve this problem the 'easy' way would be to find another good working distributor.
Old Aug 2, 2009 | 05:31 AM
Apex1972's Avatar
ya think so?
JustCant5topMe
Apr 26, 2013 09:02 PM
thedudefromjerz
Apr 21, 2009 10:19 AM
garyc17
May 2, 2008 03:31 AM
crxricer66
Jan 11, 2008 01:57 PM
s2kkid
Dec 12, 2005 06:42 AM
