crx ls swap problem need help
ok, im new to honda tech i couldnt get help from superhonda and g2ic so i hope this site is better. Ok ive done the swap but i cant get it to start the injectors arent firing or the distributor, the motor rebuilt i put crower cams in, a new swap harness the computers used but it works because i put it my zc 4dr and it ran, a brand new in the box distributor and everything. the only thing i see the guy before me had a odb1 vtec swap done at the ecu side of the harness i switched it back but nothing i dont know what to do help me
when i turn on the switch the ecu light does come on then off, fuel pump is priming 91 ecu, 91 distributor, 93 motor mpfi swap done all new fuses motor got a ground kit all lights work cant figure it out.
the guy how had the car before me had a gsr or a b16 in it before i put it back stock then did the the swap at the ecu the wiring harness is store brought
even though you bought a new harness doesn't mean it will work. 1st - check your wiring again, if they did or you did a dpfi to mpfi make sure its correct. 2nd -main relay. 3rd - fuel pump. 4th - injectors.
yea fuel pump is a walbro works fine, forgot to put on the injector seal one day and i pumped about a gallon in a second lol, but the injectors i have 2 sets ive switched and switched but nothing as far as the wiring its getting there im checking it wire by wire i was wondering what this white and red wire at the ecu no other ef has it but this one and its not on the wiring diagram
ok, i ran into another problem i started it, ran a little and cut off now im not getting anything again. the ecu blinked when it came on like it is suposed to but if i crank it for like 5 to 10 seconds the computer led comes on and stay on ive heard that that calles for a new ecu but i put it in my dohc zc and it started right up, what is going on?, and on both cars its trowing a code 4 and 9 i dont get it
I had this problem with my b20 swap into 89 hatch. It ended up being a ground wire on the back side of the motor under the intake manifold on the intake side. I got it to start sometimes and would drive it, but with the vibrations it lost connection and the car died. Be sure to check all your grounds, it may just be a bad ground. Good luck
rickscrx
19
Jan 21, 2011 12:42 PM
laoboisosilly
14
Jul 14, 2009 06:01 AM
i.love.my.cx.hatch
Mar 2, 2009 03:25 PM
