Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Need motor, someone help on jdm b20b into crv!!
Old Jul 31, 2009 | 02:19 AM
chirp the 1-2's Avatar
Default Need motor, someone help on jdm b20b into crv!!
Well my headgasket is toast and im not putting a couple hundred into a tired motor. I want to get a year appropriate jdm motor and put it in, but cannot find a link or straight info about what i will need to do to make it work.
Help save my crv
Old Jul 31, 2009 | 06:38 AM
qwrty's Avatar
Default Re: Need motor, someone help on jdm b20b into crv!!
from what i know,
it should be direct bolt on..
Old Jul 31, 2009 | 09:22 AM
black da9's Avatar
what year is your cr-v? all b20s will bolt in no problem. it just comes down to if you have a 97-98 or 99-01, and that is just because the newer ones have a bump in comp and could prolly use a little more fuel than the 97-98.
Old Jul 31, 2009 | 11:43 AM
tougetuned_ef's Avatar
hmotorsonline.com is perfect for jdm motors. they have b20's for like $600 bucks. my buddy got one from a scrap yard in the city for $600 dropped off at his house.
Old Jul 31, 2009 | 11:45 AM
heres the exact link. $550 plus shipping for 96-98 and $750 plus shipping for 99-01 http://www.hmotorsonline.com/shop/sc...age&item=30027
Old Jul 31, 2009 | 02:20 PM
i have heard u have to change over the oil pump to add a knock or crank sensor
Old Jul 31, 2009 | 04:27 PM
i dont know anything about that but if you ask them im sure they could help you out.
Old Aug 3, 2009 | 04:52 AM
www.megameet.org's Avatar
yes, you need the crank sensor from your old engine and I would just do a new oil pump and timing belt also. Dont forget to to the valve alignment asap as well
Old Aug 6, 2009 | 09:39 AM
jeff652's Avatar
Just do this (http://ff-squad.com/wp/?p=309) and save the $250-$400 for an oil pump, timing cover, and CKF sensor.
Old Oct 14, 2015 | 01:48 PM
Cdubz628's Avatar
this is good info but do you possibly have info on a jdm b20b swap into 2000 CRV ? please & thanks ??? cant find anything on the web ?
jonathan13
Apr 15, 2008 08:54 PM
EF9SIRJeff
Apr 5, 2006 03:27 PM
threatcon13
Dec 17, 2001 03:38 PM
