AEM Fuel Rail Leak - Coming from 1/8 NPT plug
Old Jul 30, 2009 | 09:23 PM
95DC2GS-R's Avatar
Default AEM Fuel Rail Leak - Coming from 1/8 NPT plug
I recently found out why I'm using so much gas.. Fuel is literally dripping from the 1/8 NPT screw plug on the fuel rail.
I tightened it earlier, but fuel is still seeping through the threads.
I know Teflon tape will get eaten away by the gas, and other sealants will too. Is there a sealant/gasket medium that I can use for this? I was getting about 35mpg hwy, now with this leak I'm getting like 22mpg.
Any help is appreciated, thanks.
Old Jul 31, 2009 | 07:07 AM
CerealKiller's Avatar
Default Re: AEM Fuel Rail Leak - Coming from 1/8 NPT plug
not to be a dick, but have you contacted AEM with the issue?
Old Jul 31, 2009 | 08:06 AM
TurboChurch's Avatar
ther are fuel type teflon tapes and sealants and they can be had at any local auto parts store. I personally have never had any of my teflon tape fail and I know its the run of the mill Lowe's/ Home Depot style teflon tape. Start your tape edge one full thread from where the fuel will contact it and tighten it up. You are over thinking the problem.
Old Jul 31, 2009 | 09:17 AM
jdm inc's Avatar
I use teflon on my fuel rail i have both holes plug up on mine and i have no problem with it leaking.
Old Jul 31, 2009 | 04:02 PM
95DC2GS-R's Avatar
I contacted AEM and they suggested teflon tape. I know from experience thougn that it can/will break down with some fuels and solvents. I'll try teflon tape, if not I'll search AutoZone for some thing.
Thanks for the help.
Old Aug 1, 2009 | 08:41 AM
jdm inc's Avatar
I ran teflon on mine for several years never had a problem but id suggest redoing it every soo often if your afraid of it breaking down.
Old Aug 1, 2009 | 08:50 AM
IN VTEC's Avatar
Hondabond HT is my preferred sealant.
Old Aug 2, 2009 | 03:19 AM
95DC2GS-R's Avatar
I used some teflon tape and it looks like it's holding up for now.
Thanks for the help and info.
Old Aug 2, 2009 | 04:19 AM
1992Si's Avatar
As long as you used 3 wraps of teflon tape you should be fine. Used it with C16, worked fine.
bumblebeehatch
Jul 15, 2013 06:11 AM
acmoc
10
Dec 15, 2008 05:06 PM
VTECth1s
May 7, 2006 07:31 PM
IIVIIoOkY
Mar 21, 2006 03:57 PM
pgpunkguy
Aug 3, 2004 02:19 PM
