no start problem.....
well i just did a intake mani gasket on my homies 94 prelude si, and no it wont start....im getting no fuel and i do no hear the relay click or the pump priming. i checked fuses and there all good, so would you guys suggest doing a main relay?
its just the weird thing about this is that it was starting fine before i did the gaskets, and the only electrical plugs i took off were the iacv, fast idle valve, tps, dual runner sensor.
any suggestions?
any suggestions?
yea ill check that ground now...it night be that. and i didnt un plug the injectors...i just took off the fuel line and poped the fuel rail off and moved it to the side.....
OMG WTF
Feb 14, 2009 12:13 AM
