K20 Head swap
F & K aren't compatible without fabrication. You're better off with a K20 block anyway. Much better off.
I would've preferred you did a search for this before asking, but I'll consider this an introductory warning. The only worthy F head is the F20C, which is also not compatible. However there are other heads that will fit:
https://honda-tech.com/forums/honda-prelude-4/arp-rod-bolts-main-studs-f22-h23-f23-h22-1738070/
If you need more, Google it. Hondas are the most commonly modified cars; almost anything you need to know is already out there.
Cheers
Cheers
The K20 in an Accord? Personally I wouldn't waste my time with a K20. I would go with a K24 if I were to swap to a K series in an Accord. But that's just my opinion.
as i lay dying
Apr 21, 2004 05:48 PM
