question about brake lines
i have a 97 dx coupe with 93 teg ls rear discs and i want to order steel braided lines....can i order lines for an si? and will they work or will i have to order 2 seperate sets??
If it's a street vehicle, find someone who makes the lines with a protective coating over the stainless braid. If you get the normal ones, dirt will get between the Teflon (PTFE) inner core and the stainless and it will wear the core out and you'll get leaks and probably careen off a cliff and land on a bunch of puppies and kittens, killing them all...because you decided to cheap out on brake lines.
Stoptech makes some, but there are others out there also and I'm in no way endorsing or knocking stoptech.
DaveSi677
Jul 28, 2006 08:56 AM
BigZ88
Dec 28, 2004 06:38 AM
Unjockable
Dec 23, 2002 10:57 PM
