steering wheel lock
Old Jul 30, 2009 | 10:08 AM
epicbeats's Avatar
Default steering wheel lock
how would you go about removing the steering wheel lock off on a 96 civic?
Old Jul 30, 2009 | 10:13 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: steering wheel lock
i did this. it will make yoru key stick alittle you gotta wiggle it to make it come out
take off the bottom plastic cover on the columen. unbolt the iginition dealy
there is a gap in it. put the key in and out to find the little rod that slides over to unlock it. i glued mine open. no lock. but key is a tad shady.
i also killed the interior dinger noise dealy. a wired right next to the lock.
Old Jul 30, 2009 | 10:59 AM
Vindicator9000's Avatar
318 Curves, 11 miles
for real? why?
Not being snide, I'm genuinely curious, as I'm the type who will leave my keys in the ignition and walk away whilst my alarm autolocks my doors. I NEED the door dinger to protect myself from my own stupidity.
So, what is your purpose for removing the steering lock? Making it easier to steal? Or do you just want to roll it around in your garage without the keys in it?
Old Jul 30, 2009 | 11:08 AM
40mpg_dx00's Avatar
I'm with Vindicator. Why make it easier to steal? If you really want to remove the lock though, take a hammer and chisel, tap out the breakaway bolts on top of the column ( which are one-time use) and drop the ignition off the column. this will expose the lock and then you can either A) fill the notch in the column
or
B) use a zip-tie or clamp around the lock on the ignition to prevent it from engaging.
option B will result in a loose ignition once reassembled but it's easy and quick.
For the record, you shouldn't do either. People could steal your car very easily as is. Why make it easier?
Old Jul 30, 2009 | 11:15 AM
H23_del_soul's Avatar
unless this is a track car, I would shy away from this.
Old Jul 30, 2009 | 11:17 AM
epicbeats's Avatar
well i have a toggle switch and push start button.i also have a 2way alarm.i just want to eliminate the key alll together.plus im going to add a couple kill switches
Old Jul 30, 2009 | 11:28 AM
I'm not Rick!
i have a kill switch for a kill switch. aint no1 stealling my shiz. ima vet that dont sleep. with a 38 special by my window all the time. It’s a weekend warrior car.
If it dies while driving it, it locks up
The dinger annoyed me. I wont forget my key, kill swithes, ecu and steering wheel
Old Jul 30, 2009 | 11:34 AM
40mpg_dx00's Avatar
Not to knock veterans, cuz I respect the hell out of them but....
EASY BRO. You seem to be wound kinda tight. Take a night off and catch some Zzz's and thanks for doin what you do
Old Jul 30, 2009 | 11:43 AM
I'm not Rick!
yeah my wife has atuff time with me. il sleep one day
thanx
Old Jul 30, 2009 | 07:40 PM
H22a_bubbleback's Avatar
With the need for a gun and a billion kill switches on the car along with a name like Rick_Rabies....I think you might need a series of shots, but your condition might already be to advanced. :-P
Old Jul 30, 2009 | 07:55 PM
fastrxu's Avatar
I wouldn't tamper with the ignition and just keep an alarm and a clutch club to keep thieves away that way I make sure I don't HAVE to use the .38 super
SoCalCivic498
Apr 20, 2015 08:37 PM
1stgenboost
Feb 25, 2009 09:24 PM
sillyboybmxer
12
Jul 10, 2007 10:57 PM
ludedudeh23
Oct 29, 2004 04:33 AM
dingusjt
Jun 10, 2004 04:50 PM
