Need help! coolent leaking on my teg......
Old Aug 24, 2002 | 12:18 AM
Integvalier's Avatar
New User
Default Need help! Something is leaking in my teg.........help...
hey, i don't quite know much about cars..........
but my car is leaking coolent.......it's leaking from the hose where my short ram intake is sitting on.
i think all of coolent is almost gone....the little white box is emptied!
is it still safe for me to drive? what should i do? patch the hose or just goto a garage and get it fix ASAP.
i know this is a dumb question...........but hey.......i am a noob.......
[Modified by Integvalier, 9:20 AM 8/24/2002]
[Modified by Integvalier, 9:55 AM 8/26/2002]
Old Aug 24, 2002 | 12:23 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: Need help! coolent leaking on my teg...... (Integvalier)
well, first, fill up the coolant... if oyu dont have any coolant available right now, the most important thing is water so put in some water until you CAN get coolant.
also, at first glance i thought it said "coolent leaking on me leg"
Old Aug 24, 2002 | 12:25 AM
New User
Default Re: Need help! coolent leaking on my teg...... (dLo GSR)
can i drive to a nearest garage without any water or coolent?
it's about 5 km away.
Old Aug 24, 2002 | 01:57 AM
just pour some water in the there. it won't hurt. all the antifreeze does is raise the boiling point of the water, so that it doesn't evaporate. so the water will evaporate, but it's better than running with nothing in there at all. then you can go tot he store
Old Aug 24, 2002 | 02:16 AM
tC_Dragon's Avatar
not sure which hose ur talkin bout but make sure all the fittings are snug... u might have messed the coolant hoses that lead to the bottom of teh throttle body. Or torn them. But yea.. put some water in teh coolant tank and u should be alright to drive... butkeep an eye on the temp guage, if it goes up too high then don't drive.. u don't wanna overheat and blow a head gasket.
Old Aug 24, 2002 | 02:19 AM
poison's Avatar
Default Re: Need help! coolent leaking on my teg...... (pdcdragon)
The hose you are speaking of is the Heater Core hose from the thermostat housing to the heater core.
Drain your coolant, take off the hose and get a new one (which will cost you about 5 bucks), and get yourself some coolant, and you are done.
Old Aug 25, 2002 | 07:05 PM
New User
Default Re: Need help! coolent leaking on my teg...... (poison)
okay, i got some pix........here's the leak.........in the red circle........it showes up yellow in the pix becasue of a flashlight..........not rust or anything
ok, here's the end where i can take off the hose..........but where does the other end go? i can't get to the other end. it goes deep under the battery. i can't quite reach the other end with my hand. Do i need to take apart other stuff to get to the other end? instructions on how to remove it will help alot...........THANKs!
here's another pix. Can someone tell me what part number or name is that hose?
THANKS guys!
[Modified by Integvalier, 4:08 AM 8/26/2002]
[Modified by Integvalier, 4:18 AM 8/26/2002]
Old Aug 25, 2002 | 10:16 PM
New User
help!...........thanks
Old Aug 25, 2002 | 11:02 PM
bikeboy80's Avatar
that sure looks like one of your a/c lines and not coolent
Old Aug 25, 2002 | 11:29 PM
New User
Default Re: Need help! coolent leaking on my teg...... (bikeboy80)
a/c line.......eh?
how much is it around to get it fix...........? you think?
Old Aug 26, 2002 | 03:01 AM
ragejed's Avatar
free if you remove all your A/C components, lol. Not sure about this, but dont you need to drain the system to do work on A/C lines?
Old Aug 26, 2002 | 03:57 AM
bikeboy80's Avatar
Default Re: Need help! coolent leaking on my teg...... (ragejed)
just to check try turning on your a/c and see if its cold, any thing with the a/c is not cheep to fix
as for the system needing to be drained, if there was stuff leaking out of that hole, the system is already drained
Old Aug 26, 2002 | 08:50 AM
TenaciousC's Avatar
definitly is an a/c line
Old Aug 26, 2002 | 10:16 AM
GSRaCeRbOI's Avatar
Default Re: Need help! Something is leaking in my teg.........help... (Integvalier)
from what you have circled in the 2nd pic.. looks like a high side A/C line to me..
Old Aug 26, 2002 | 01:50 PM
New User
help!?
Old Aug 26, 2002 | 02:06 PM
eastsidemags's Avatar
a/c system is presurized and leaks are bad go to the garage and be sure to give them some sugar after they **** you !
Old Aug 26, 2002 | 04:34 PM
iH8RICERZ's Avatar
Default Re: Need help! Something is leaking in my teg.........help... (eastsidemags)
sheit..i have a fat *** coolent leak on my gsr cause my radiator is cracked some where. So i'm in search for a new radiator...anyone??????
Old Aug 26, 2002 | 04:49 PM
mr_mbuna's Avatar
Default Re: Need help! Something is leaking in my teg.........help... (iH8RICERZ)
Fluidyne and don't think twice about it. Aluminininium.
Ben
Old Aug 26, 2002 | 07:59 PM
New User
Default Re: Need help! Something is leaking in my teg.........help... (mr_mbuna)
ok.......i went to a garage, and the mech told me there's 2 options...........
WELD it.......patch it..........for 200CDN. from a local radiator shop.........
or get the whole hose replaced for 330CDN.. from canadian tires..........
which one should i go with?
[Modified by Integvalier, 5:01 AM 8/27/2002]
Old Aug 27, 2002 | 12:26 AM
qwkteg125's Avatar
so is your car still loosing coolant after you refilled the tank?
Old Aug 27, 2002 | 03:30 AM
bikeboy80's Avatar
Default Re: Need help! Something is leaking in my teg.........help... (qwkteg125)
does any one know if that piece of ac line is the same in 5th gen hatches? i just pulled the a/c from my hatch and still have all the lines, i would be happy to send you it for like $20 us if it is the same, then you can just put it on your self and then take the car someplace to have the system charged, it should be alot cheeper then both of the other options
Old Aug 27, 2002 | 12:08 PM
poison's Avatar
Ben
or C&R
both aluminum radiators own!!
BadassEFdriver
Jun 20, 2011 06:12 PM
v-tec maz
Oct 12, 2005 12:00 PM
Paprika
Dec 21, 2004 04:51 AM
blkbeast
Feb 6, 2002 02:48 PM
