will a milled head ported and polish still pass ca smog???
just wanted to know if a b16 ported and polish head done by portflow still pass smog in CALIFORNIA if installed to my b16a3??? bottom block will be stock but for the head it is done by portflow with supertech valvesprings, itr retainers, itr cams. the rest of the motor is pretty much stock just dc header and aem intake.
just talked to my buddy with a pnp head oversized valves, milled and he still passes no problem. he lives in Sacramento as well.
and on the off chance they do ask, just tell them the motor was rebult and you milled it because the shop reccomended you do
doesn't milled head = higher compression = more nox? just a question...
well yes. but you only mill so much,
whitch isnt going to rasie comp to much.. he only did it to make sure the head was flat.
but if you are worried about it you can alway put a thicker hg in and the should lower it right back to oe.
i doubt you will even see a half a point raise in comp. although i may be wrong.
When they surface a head, they usually only take a little tiny bit off. Would the cams allow more unburnt fuel to pass through, since they probably have more overlap?
Let us know how it turns out.
Skank_aSS_Dara
Oct 20, 2004 11:23 PM
