ABS light..no code..what next??
Old Jul 30, 2009 | 06:01 AM
RotaryPWR's Avatar
Icon2 ABS light..no code..what next??
The car: 98 civic ex coupe
so after changing the pads on the car, i noticed the abs light came on and stayed on. I went to check codes by shorting the connector with an insulated wire, but the abs light stayed solid (no flashes). i have checked CELs many times using the same method, so my procedure should be good..so i followed the steps to reset the light (depress brake pedal, ignition ON, abs light off, release pedal, abs light on, depress pedal, abs light off) but the light came back on.
so i gave up for a bit, researched, found nothing but "check for codes" posts, and tried getting codes again. same thing happened, but now i can't seem to even get the abs light to reset..i even extended and cleaned up the ends of the insulated wire to ensure a good connection when shorting.
just wondering what i should do now? my haynes manual doesnt suggest anything for when you don't get any codes.
is it possible my brake cleaner damaged the abs sensors? i chose to use the cheaper normal brake cleaner rather than the abs sensor safe cleaner..the sensors are squeaky clean too. i don't understand how that would affect the reading of codes though..
thanks in advance!!
Old Jul 30, 2009 | 07:16 AM
Former User's Avatar
Default Re: ABS light..no code..what next??
Old Jul 30, 2009 | 10:56 AM
RotaryPWR's Avatar
another thing..i've heard a bit about how there is an abs connection to the battery and that a lose connection sometimes causes problems..can somebody post a pic of where that connection is exactly?
Old Jul 30, 2009 | 11:18 AM
Originally Posted by RotaryPWR
The diagram is an excerpt from the 96-00 Civic service manual. It tells you several items to troubleshoot when the ABS light is on but no ABS codes are retrieved.
Old Jul 30, 2009 | 11:55 AM
RotaryPWR's Avatar
oh i see..i can't see it using the computer i am on right now. shows up as a blank post!!
thanks, i will check it when i get home!!
Old Aug 11, 2009 | 11:11 AM
RotaryPWR's Avatar
i stopped messing around with the abs issue to solve a few other issues, but i'm back.
can somebody please tell me how to check for an open in the IG2 circuit?
how do i check for a short to body ground?
how can i check for a faulty abs control unit?
i've searched all over without finding any clear info, and the hayne's manual i use for repairs says "abs systems are complicated. bring it to a professional." but i thought i would mess around with it a bit first before i take it in..
Old Aug 11, 2009 | 01:16 PM
See diagrams below.
Old Aug 12, 2009 | 11:36 AM
RotaryPWR's Avatar
Thanks for that!!
turns out the abs battery connector was not connected securely enough. before trying any of these tests, i did a thorough clean of my bat and connectors, and used a new bolt to connect the abs to the bat.
drove to work this morning and the light turned off for good. all i gotta do is test the system to make sure its actually working!!
*smack myself in the head*
94coupeNA
Jan 26, 2006 12:56 PM
FLATOUTRACING
Dec 11, 2005 03:06 PM
f22suzuka
Apr 21, 2004 10:15 AM
CNSK
Apr 12, 2003 11:13 PM
redteg1
Aug 18, 2001 02:42 PM
