check engine light in higher speeds
Old Jul 30, 2009 | 12:20 AM
shyguy4no1's Avatar
Default check engine light in higher speeds
Hey guys I am a bit confused right now about a check engine light problem that i am having. At lower speeds I have absolutely no problem with anything when it comes to my car. However the second I hit highway speeds I get a code 1 and a code 16. And I really don't get it. I am dumbfounded by this one and can really use some help thanks in advance.
Old Jul 30, 2009 | 08:05 AM
B16-CRX's Avatar
Default Re: check engine light in higher speeds
Code 1 is primary oxygen sensor and 16 is a fuel injector problem. they are most likey related because a bad injector or faulty injector wiring will affect your o2 readings. I would check out your injectors and the wires going to them and maybe you will find something.. good luck
jayrod7
Jan 21, 2010 01:45 PM
theharlequin
Apr 13, 2004 12:00 PM
xcathodex
Mar 20, 2003 07:44 AM
b16awarrior
Jan 23, 2003 11:48 AM
