Taking off from a stop, engine bogging/hesitating.
Old Jul 29, 2009 | 08:25 PM
Mad Third Gear Vtec's Avatar
Default Taking off from a stop, engine bogging/hesitating.
I roll up to a stop sign.
Come to a complete stop.
Accelerate in first gear and engine bogs/hesitates, and I have to immediately step on the clutch and rev the motor a little to achieve a higher RPM to, honestly, avoid embarrassment lol.
But from a complete stop, if I rev the motor to 2k RPM's and then take off, the take off is fine. No hesitation.
Old Aug 2, 2009 | 10:14 AM
Default Re: Taking off from a stop, engine bogging/hesitating.
bump - need some input.
Old Aug 2, 2009 | 10:43 AM
street_ride14's Avatar
it's spark or fuel related. When was the last time you did a tune-up ?
Old Aug 2, 2009 | 11:06 AM
I was thinking the same thing. I just bought the car, but when I test drove it, there was no bogging/hestitation whatsoever.
I decided to replace the distributor cap & rotor, valve cover gasket kit and spark plug tube seals, and distributor wires.
I believe an oil change and new NGK spark plugs will be next on the list.
I believe it may be this also since there is hesitation around 3k: https://honda-tech.com/forums/honda-prelude-4/no-more-3k-hesitation-better-gas-milage-smoother-partial-thottle-response-2016969/
I looked at the EGR valves, and it looks like they were already tampered with, JB welded I guess.
What kind of tune-up would you recommend?
Old Aug 2, 2009 | 11:14 AM
Start off by replacing your plugs and wires., then replace fuel filter using OEM Honda. Do you notice this happening in generally hot days ?
Old Aug 2, 2009 | 11:43 AM
Well its summer and everyday in Cali is hot lol. When I first start the car, pull out of my garage, and drive off, I won't notice it. But once I get to the 2nd stop sign, literally 30 seconds later, I'll take off and notice the hesitation/bogging in the below 3k range.
Old Aug 6, 2009 | 07:04 PM
h2b eg's Avatar
ngk plugs or the new e3 plugs are very good and get a good set of wires and go from there
Old Aug 7, 2009 | 05:49 AM
H23_del_soul's Avatar
fuel filter.
97civic07gsxr
10
Apr 6, 2009 07:16 AM
austinkli
23
Feb 7, 2008 12:57 PM
yarara0825
Jan 4, 2008 04:44 PM
rohec04
Sep 28, 2005 04:11 PM
is3oo
Jun 26, 2002 10:58 AM
