Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
changed cam plug now car is missing?!?!?! please help
Old Jul 29, 2009 | 03:02 PM
redb16coupe's Avatar
Default changed cam plug now car is missing?!?!?! please help
ok i changed the cam plug on my 01 ex, now i have a miss on the cylinder closest to the timing belt, changed the coil packs around to see if it was that but still does it, have a check engine light on. is there any way we can check the codes with out a scanner? im really stumped this car is my daily and im screwd... some one please help
Old Jul 29, 2009 | 06:01 PM
Default Re: changed cam plug now car is missing?!?!?! please help
bump
Old Jul 29, 2009 | 06:05 PM
HONDAPARTSMANMIKE's Avatar
did u lossen the cam cap??if so did u adjust the afterward??
Old Jul 29, 2009 | 06:13 PM
yes i did loosen the caps, no i didnt adjust?>>
Old Jul 29, 2009 | 07:18 PM
did you loosen all of them??did you remove the rocker arms at all??
Old Jul 29, 2009 | 07:59 PM
SGolub's Avatar
Very misleading thread title.
Old Jul 29, 2009 | 08:31 PM
90sedan's Avatar
Check and adjust the valves to factory specs and then report back.
Old Jul 29, 2009 | 08:37 PM
jdmfreak1992's Avatar
Timing correct. Make sure the belt didn't skip any teeth
Old Jul 29, 2009 | 09:53 PM
It Wasn't Me's Avatar
If the belt skipped a tooth, the car would not run.
Old Jul 30, 2009 | 06:54 PM
you where totally right. i had 110 compression on #1 and 135 on the rest figured that when i loosened everything i had to re-adjust the valve lash, now i have 150 across the board.
thanks
Oney
Old Jul 30, 2009 | 10:36 PM
thats good to hear!! is the car running good now??
Old Jul 31, 2009 | 06:52 AM
Better than before, car is running alot smoother and has so much more power i think the lash was really off before and i just made it worse.
Devon M
Sep 30, 2014 04:30 PM
giovannie23
Oct 10, 2013 02:22 AM
skata89
Dec 19, 2006 09:03 AM
cooteg6
May 19, 2006 06:21 PM
EK4 hatchback
May 31, 2004 08:45 PM
