PA Turbo 91 ef hatch. Testing waters.
Heres my 1991 Si Civic hatchback... NO LONGER FOR SALE OR TRADE... in process of being change around.
JDM ITR b18c. (engine currently is making 450whp on 19psi)
hasport mounts
eagle rods
nippon pistons
type R cams
Type R valvetrain
Skunk2 tuner cam gears
arp head studs
Oem head gasket
type r throttle body
Edlebrock victor x intake
BDL Fuel rail
jegs fuel filter and an fittings
walbro 255 fuel pump
aluminum radiator.
koyo rad cap
skunk2 vtec solenoid cap
hks blowoff valve
hks oil catch can
ccfab ramhorn manifold
borgwarner s362 turbo
aem dryflow filter
precision 880cc injectors
tial 44mm wastegate
goautoworks intercooler
custom made intercooler pipe
custom 3 inch exhaust
Avid shift linkage
energy poly bushings.
rims/rubber
15x6.5 rota slipstreams fully polished/ or 5zigen FN01R-C Bronze.
195 50 15 kuhmo tires
muteki sr48 rainbow lug nuts
blox extended studs
ouside.
Vis carbon fiber hood
benen limited edition tow hooks
skunk2 lowercontrol arms
custom made front traction bar
k-tuned backside front traction bar
ef 9 cornerlights
1991 DA rear disc brake conversion
drilled and slotted rotars
ebc brake pads
skunk2 sport struts
dropzone coilovers
j's racing front lip custom fitted to fit usdm front end
Interior.
ITR steering wheel
Ukdm si cluster
Passwordjdm shift boot
sparco 4 point harnesses
sparco speed seats
sparco floor mats
custom made roll cage. by me.
usdm gsr centerconcole
skunk2 short shifter
skunk2 shift ****
autometer boost and oil gauge
innovative digital wideband gauge
hasport mounts
eagle rods
nippon pistons
type R cams
Type R valvetrain
arp head studs
Oem head gasket
BDL Fuel rail
aluminum radiator.
koyo rad cap
hks blowoff valve
hks oil catch can
aem dryflow filter
tial 44mm wastegate
Avid shift linkage
rims/rubber
blox extended studs
ouside.
ef 9 cornerlights
ebc brake pads
skunk2 sport struts
dropzone coilovers
Interior.
ITR steering wheel
Ukdm si cluster
sparco speed seats
sparco floor mats
skunk2 shift ****
Trade plus cash my end?
http://www.hondamarketplace.com/show....php?t=2513169
interested in a trade....
http://hondamarketplace.com/showthread.php?t=2578149
dude thats 1 facking bad *** ef! how many psi are you running?? and what was the charge for the roll cage painted? and was it done in the car??
