noob questions on build of b16a2
Old Jul 29, 2009 | 11:56 AM
migrod1's Avatar
Default noob questions on build of b16a2
i just aqcuired a 2000 civic si with a b16a2 and would like to build the motor up just to the next level. this is my daily driver so i wouldn't want to do anything too dramatic. the car has AEM cold intake, thermal R&D exhast system, aftermarket headers. i dont want to turbo the motor becuase its my daily driver, what im thinking of getting
1. skunk2 stage one tuner cams
2. aem tuner cam gears
so my question is: what else would i need to build up this motor? hondatas???? and skunk2 retainers and springs?
id also like to know what kind of price range am i looking at? if possible anyone that has done can give me some advice on this subject
Old Jul 29, 2009 | 01:34 PM
redlinetuning's Avatar
Default Re: noob questions on build of b16a2
how much are you looking to spend? What is your power goal? What do you intend to do with it? DD/weekend warrior... AutoX? Drag? HPDE?
Old Jul 29, 2009 | 01:36 PM
vtechjunkie's Avatar
Stage 2 cams usually require springs and retainers. But if it is a dd then I would just get some itr/ctr's for it.
Old Jul 29, 2009 | 02:18 PM
1988_96hb's Avatar
id drop in a gsr but if u dont want to go that far just get itr cams and some skunk2 gears.
Old Jul 30, 2009 | 05:14 AM
migrod1's Avatar
well its going to be my daily driver and ill go auto crossing like 4-5 times a year, do pretty much DD/Weekend warrior. some other things i have on the car are skunk2 springs, 16" rota slipstreams, energy suspension shifter busings, skunk2 short shifter and ****, some stuff waiting to be installed are new gauges, black housing headlites, F1 fenders, corbon fiber hood.
any more info from someone thats put stage 1 skunk2 cams
Old Jul 30, 2009 | 05:43 AM
tercel95's Avatar
I have the skunk2 stage 1 cams and I am very happy with them... They definitely outperform Type R cams... It is not required but I replaced the springs/retainers as well as the valves with skunk2 parts... The springs/retainers will allow you to rev a little bit higher... My rev limit is set at 8800 rpm...
The MOST important thing is tune, without a tune we are talking like a 2hp gain and your car will run like garbage... Absolutely get it dyno tuned not one of those BS mail order basemaps...
Overall I am very happy with my setup as a DD car...
Old Jul 30, 2009 | 05:57 AM
migrod1's Avatar
can you tell me your whole set up for you car? also can you tell me how much you've spent?
Old Jul 30, 2009 | 06:18 AM
tercel95's Avatar
K&N FIPK, skunk2 tuner stage 1 cams, skunk2 springs/retainers, skunk2 valves, Random Tech cat, Apexi WS2 exhaust, chipped P28 ECU, skunk2 short shifter with ES bushings, ACT stage 2 clutch, ACT streetlite flywheel...
If you care:
s2000 seats, skunk2 pro-s coilovers, skunk2 LCAs, Brembo blank rotors, Hawk HPS pads...
I would say I have about 3.5k in the engine/drivetrain not including routine/preventative maintenance... Also I did alot of the work myself...
Old Jul 30, 2009 | 06:25 AM
migrod1's Avatar
If you care:
so do you how much horsepower you have with this setup?
Old Jul 30, 2009 | 07:05 AM
tercel95's Avatar
It was street tuned by a buddy of mine who does ecTune... I would estimate it around 185 crank hp... I said to get a real dyno tune because that is the way to go to extract the most power out of your car... I am just done investing money in the car at this point... Hopefully in the next year I will buy another car and have this one up for sale...
I had a mail order tune, and it ran worse than with the stock ECU... It was constantly fouling the plugs and wouldn't idle for crap... My buddy got it to where it isn't running so rich and pulls pretty well up high...
Old Jul 30, 2009 | 07:30 AM
migrod1's Avatar
did you have to convert your harness to obd1 or did you keep it obd2? did you pass emissions?
Old Jul 30, 2009 | 08:10 AM
tercel95's Avatar
I bought an OBD II to OBD I coversion harness when I ordered the chipped ECU... I didn't have emissions where I lived in MD and I don't have it here in FL either...
When I lived in a county with emissions, the car would pass with the cams and stock ECU... I would have to reset it right before I went through though because after driving for awhile the car would throw a CEL for running too rich...
YoungMoneySi
30
Dec 16, 2012 05:57 AM
migrod1
Aug 1, 2009 03:18 PM
xrocket21
Mar 6, 2003 03:48 PM
w1se
Mar 7, 2002 09:40 PM
