Clutch Cable
Old Jul 29, 2009 | 06:12 AM
toolbox21's Avatar
Default Clutch Cable
Got A CRX With A Z6 Swap, Just Put A New Si Tranny In With Exedy Clutch, And I Have A DX Clutch Cable, Its Adjusted All The Way Tight And The Release Point Is Like Right Of The Floor, So Is There Any Other Clutch Cables That Are Shorter And Allow For More Adjustment
Old Jul 29, 2009 | 07:54 AM
toolbox21's Avatar
Default Re: Clutch Cable
ttt
Old Jul 29, 2009 | 09:20 AM
4drEF's Avatar
Keyboard Humorist
There shouldn't be any difference from the DX to the Si (cable, right?) tranny as far as your clutch cable goes.
Sounds like something isn't hooked up correctly at the tranny - bracket, cable grommets, etc.
Old Jul 29, 2009 | 02:48 PM
johnnyonth3spot's Avatar
do you have your clutch cable bracket on your motor, it makes a difference. I bought a zc swap last summer and fought my clutch cable for months before I realized the I had no brackets on this motor, the zc I got was an auto before I got it. Your cable could also be stretched if its an older cable but I dont know if there is a difference between dx and si... I would have to say no but thats just guessing.
Old Jul 29, 2009 | 07:05 PM
FOMULA91's Avatar
CRX clutch cable are all the same. Also, is the Exedy clutch new? When you have a new clutch, it takes time to get use to it and the engagement point is very close to the floor.
Old Jul 29, 2009 | 08:08 PM
tronsteez's Avatar
cable stretch.
buy some fat washers cut a notch in them and slip them in between the ajustment **** and the cable bracket.
that is if your cheap like me...
If not go buy a new cable
Old Jul 29, 2009 | 10:14 PM
toolbox21's Avatar
yeah the clutch is broke in. i mean i think it may be stretched, im either gunna try modding my bracket to get more adjustment or just do the washer idea. thanks for the info.
Old Jul 30, 2009 | 12:23 AM
tronsteez's Avatar
glad to help, I got some nylon washers from ace hardware that are pretty thick and just zipped a notch in the sides of them to slip them over the cable.
works great and was like 2 bucks
Old Jul 30, 2009 | 12:59 AM
hisnibs's Avatar
Is your clutch pedal bent?
My old sedan's clutch pedal was so weakened that I could move it 3" in any direction.
Old Jul 30, 2009 | 06:15 AM
ef-hatchcrap's Avatar
Just crash the car into a tree then get a new one with a b17
crex23
Jul 11, 2009 07:36 PM
rextec
Oct 28, 2003 10:11 AM
