Dead time specs for PTE 1600cc (bosch) injectors
Old Jul 28, 2009 | 04:57 PM
KillerBee18's Avatar
Default Dead time specs for PTE 1600cc (bosch) injectors
I am installing and getting a set of 1600cc injectors machine and re-labeled by precision they are the bosch part number - 0280150842 blue tops and I just can find the specs anywhere to fill in the injector voltage compenstion table for Hondata SManager software the table is in the format of voltage vs. dead time (ms) or if I cannot obtain specs what is recommended that I do?
Thanks
Old Jul 28, 2009 | 06:36 PM
Blown90hatcH's Avatar
Default Re: Dead time specs for PTE 1600cc (bosch) injectors
Ask precision.
Old Jul 28, 2009 | 08:35 PM
locash's Avatar
If Precision can't do it, you can have them properly flowed by the Injector Dynamics guys..
Old Jul 28, 2009 | 08:42 PM
I found a link on injector rehab for the ford motorsport 1600cc and I know ford also uses bosch injectors, have any one else used the data on this chart for the ford 1600cc with good results? link - http://injector-rehab.com/kbse/lag.htm Another thing is all I have heard about precision's tech support with the injectors is we "don't know", which is not suprising since all they do is machine them to fit and put them in a package that says precision. Anyways its worth a shot, I will give them a call.
Old Jul 29, 2009 | 06:59 AM
The sweed's Avatar
I tried to get spec from PTE but they did not even know if there was 4-1 peak and hold injektors.. Sad..
Old Jul 29, 2009 | 03:34 PM
tony1's Avatar
Those values from Injector Rehab aren't even close for 3 bar fuel pressure and a proper drive circuit.
You're going to need to send them to Injector Dynamics if you want correct data.
Old Jul 29, 2009 | 03:36 PM
Mrbustanut's Avatar
When are the 2000cc injectors getting released?
tony1's Avatar
1-2 weeks
Old Jul 29, 2009 | 05:30 PM
Saturated Tony?
Old Jul 29, 2009 | 05:51 PM
tony1's Avatar
The ID2000's? Yes, high impedance.
Old Jul 29, 2009 | 06:09 PM
Hmm...interesting. Might have to do four 310s and four 2000s..lol
Old Jul 29, 2009 | 06:11 PM
boostedh22a's Avatar
Seriously? Any more info? Are they coming out with anything in between the 1000's and 2000's.
Haha, that's what I was thinking.
Dark_Teg
Jun 30, 2014 05:44 AM
dester223
Nov 11, 2013 12:44 AM
accord_raffi
Jan 27, 2009 07:31 PM
gamakichi77
Oct 5, 2004 04:07 PM
JDM Queen
Jan 29, 2004 05:22 PM
