CAR SMOKES ?
Old Jul 28, 2009 | 04:06 PM
oldschoollove's Avatar
Default CAR SMOKES ?
ok so when im driveing and i get on the gas the car start to puff out white smoke ..could this be be valve seal and if so any one have any links thanks
Old Jul 28, 2009 | 04:24 PM
LightWeightED8's Avatar
Default Re: CAR SMOKES ?
http://www.nicorette.com/
http://www.youtube.com/watch?v=KsMcJaSPaoM
Old Jul 28, 2009 | 04:30 PM
Ill be serious now What color is the smoke? Black? White? Grayish/Blue?
Old Jul 28, 2009 | 06:04 PM
lol...... its white
Old Jul 28, 2009 | 06:19 PM
Radim's Avatar
Coolant, probably bad headgasket.
Old Jul 28, 2009 | 06:21 PM
black0hatch's Avatar
i thought white smoke is oil?
Old Jul 28, 2009 | 08:22 PM
dacrxguy's Avatar
you thought wrong
white waterz
blue oil
black is hc
Old Jul 29, 2009 | 03:36 AM
Ok so it the head gasket and not the seals that's good to know lol I never changed out the valve seals
Old Jul 29, 2009 | 08:58 AM
Sounds like a head gasket. Do a compression test and see what number you et
Old Jul 29, 2009 | 09:25 AM
4drEF's Avatar
Keyboard Humorist
Check your oil and see if it's milkshaked.
Also check in your radiator and see if there is oil floating on top of the water.
Old Jul 29, 2009 | 10:19 AM
No water in the oil and no oil radiator
Old Jul 29, 2009 | 10:26 AM
When you checked your oil for sludge , did you open your vavle cover and check or better drain to see it?
Old Jul 29, 2009 | 10:34 AM
I look at the dip stick and removed the valve cover
Old Jul 29, 2009 | 01:24 PM
Does it happen all the time or just in the early morning or when warming up??
Old Jul 29, 2009 | 02:55 PM
When the car warmed up and if I diver its fine but ones I try go fast it starts to smoke and after we keep smoking as I'm driving
Old Jul 29, 2009 | 03:01 PM
What are you smoking on????
Old Jul 29, 2009 | 03:26 PM
ok look i get in the car let it warm up then then when im driveing its cool but ones i go full throttle it starts to smoke and then after will keep smoke ..now mind u its not a lot of smoke like i cant see behind me or some thing ...and sorry the last post i did was from my blackberry lol
Old Jul 29, 2009 | 09:14 PM
jdmef69's Avatar
does it smell like burning oil or anything?
Old Jul 31, 2009 | 09:58 PM
ok soo i removed the head and the head gasket was no good so i replaced it with a new one and replaced my water pump ...now the cars idie is way off and sound and is running bad and is still smokeing ...so my new ? is how to set the head and block at tdc i have done it on my ek before but on the ef there are no marks ?
Old Jul 31, 2009 | 10:00 PM
BiG ChOr!Zo's Avatar
there should be a mark on the cam gear and on the crank pulley...!!!
Old Jul 31, 2009 | 10:27 PM
lunalink's Avatar
im doing this to my friends eg.. on the cam it has a mark that reads UP , set that to 12 o'clock thats your TDC...
Yo bigChorizo who's on your avatar another been there done that?
Old Jul 31, 2009 | 10:28 PM
si
Old Jul 31, 2009 | 10:29 PM
lunalink's Avatar
we need pics bro!
Old Jul 31, 2009 | 10:30 PM
lunalink's Avatar
it also has 2 lines on it it looks like this
__ UP __
pic in my avatar
