PLease Need Help Code 8
Old Jul 28, 2009 | 02:33 PM
crxnonvtec's Avatar
Default PLease Need Help Code 8
Im firing a code 8 I changed the dizzy but the code came back after I reset the ecu....anything else make a code 8 ?? its a dpfi to mpfi swap...would mixin up the white wires cause this code too?
Old Jul 28, 2009 | 03:29 PM
hisnibs's Avatar
Default Re: PLease Need Help Code 8
Try checking your wiring with rywires chart, here http://www.rywire.com/store/images/t...or_pinouts.jpg
Old Jul 29, 2009 | 08:16 AM
crxnonvtec's Avatar
thanks Im at work right now but ill be takin off soon to go double check the dizzy wiring....no other things I might need to check for a code 8?
Old Aug 28, 2009 | 10:37 AM
crxnonvtec's Avatar
y was there a difference in the distributor pinouts?? the more I thought about it y would the pin positions switch on the plugs?
Old Aug 28, 2009 | 10:45 AM
dephtone's Avatar
Code 8 is TDC position sensor.
Should look like this at the dizzy:
Double check those wires and also the ones under the dash at the ECU plugs.
Old Aug 28, 2009 | 10:54 AM
crxnonvtec's Avatar
i know what the code 8 was I asked a differant question
Old Aug 28, 2009 | 11:01 AM
dephtone's Avatar
You asked if anything else would cause code 8 and I suggested you double check the wires as it;s either the wiring is wrong or the ECU is bad.
TDC wires are already ran for DPFI, hence why I said it would be an issue with the wires or the ECU.
I'v never swapped around the plugs like rywire suggests *shrugs* I ran the CYP wires and was done.
Also TDC can be thrown off by your timing not being correct also.
Old Aug 28, 2009 | 11:13 AM
D16SiHatch's Avatar
yea i would try following this writeup for doing dpfi to mpfi and see if it helps you figure out what went wrong
http://hondaswap.com/swap-articles/d...writeup-49557/
superslowcrx91
Sep 30, 2013 12:54 PM
oldschoollove
Nov 21, 2009 02:17 PM
1_SC_GSR
Aug 14, 2006 10:24 PM
Schaz
May 16, 2005 07:34 PM
