need help asap 02 sensor
ive got a b20 in my eg. im tryin to hook up my o2 sensor to run a a/f gauge. there is no clip on the o2 sensor so i dont no where it hooks up. can i run wires off of the o2 into the clip that goes to the harness? what wires go to what? there is white green and i believe 2 black. or can i hook up the o2 sensor directly to the gauge? how do i power the o2 sensor?
what lol?
is this a narrowband sensor... should have come with detailed instructions as to what wires to splice into.... if not good luck i cant help you there.
if its a wideband sensor it just plugs into the abck of the guage... then run power and ground
its the stock sensor i believe but there is no clip that goes to wherever it hooks up to. i ran a wire to the white wire from the gauge on the o2 sensor. there is a green and 2 black. how do iget power to the sensor? or can i splice into wherever it connects on the harness?
here is the sensor taken from the driver side looking down under the intake.
here is 2 plugs that i dont no what they go to but i believe they are my o2 sensor plugs. the one to the right had the other end in it but the wire are clipped.
here is the color of the wires for the bigger plug.
heres the smaller one. yellow and green wires
if these arent the o2sensor plugs then what are they n what goes to them?
ok thanks. do you know what the other one might be? its a b20 with no cat on it. just straight 2.5 exaust all the way back. maybe for a rear o2 sensor? or could that be the plug for my intake air temp sensor since my cel is throwing that code?
And look in the general area of where those two connections are loose (under the dist area, on the top of the tranny) and see if there's something without the wires connected.
novtecnoboost
Feb 11, 2007 06:56 PM
PH3593A
Oct 13, 2004 10:14 AM
Ooh somehow got the wrong picture. It's the other one with the white connection inside...sorry
