Mini me swap Problem..Really need HELP! please someone help
Old Jul 28, 2009 | 11:32 AM
cns21's Avatar
Default Mini me swap Problem..Really need HELP! please someone help
HELP! PLEASE!
Okay I did a mini me swap b7/z6 the motor is fine i would say i mean i got spark and fuel but it just wont turn over. bought new spark plugs and wires and a brand new distributor. but i just dont know what may be the problem. can some one please help me out..Been working on this stupid car for almost 3 months and still dont know whats the problem. Went over the wiring like 100
times. I know the timing is dead on. I just dont know why it dont start. Please someone help me! Thanks.
Old Jul 28, 2009 | 12:02 PM
dephtone's Avatar
Default Re: Mini me swap Problem..Really need HELP! please someone help
At any point does it act like it wants to start like even a little sputter like it wants to start or does it have the same tone just cranking over?
Throwing any check engine lights by chance? Which ECU are you running? OBD0 or OBD1?
Old Jul 28, 2009 | 02:03 PM
cns21's Avatar
obd1 p28ecu, yea i sputter once then after that its just the tone of the cranking
Old Jul 28, 2009 | 03:05 PM
blazzer's Avatar
you sure your spark wires are insatlled correctly?
what kinda injectors did you use?
if you used the z6 intake mani did u use the high impedence injectors or low impedance?
if you switched them at all have you checked you wiring on them and made sure there firing correctly( i had an issue with this so figured id ask)
Old Jul 28, 2009 | 09:34 PM
cns21's Avatar
Yea everything is firing right.. its just i dont what else is wrong..
Old Jul 29, 2009 | 02:18 AM
blazzer's Avatar
is your battery dying? lol or you alternator????? figured id ask
seriously though, like said above( i didnt see an answer) are you throwing a cel a.k.a ecu codes at all?
Old Jul 29, 2009 | 04:56 AM
cns21's Avatar
Yea the battery is charged, we used jumper cables and still dont seem to start. i just bought a new alternator. and the ecu isn't throwing any codes
Old Jul 29, 2009 | 05:02 AM
accordaffair's Avatar
can you try a known good ecu?
Old Jul 29, 2009 | 06:22 AM
toolbox21's Avatar
yeah try using a friends p28 or even a p06 will start it, but are you sure in time, and for that specific mini-me you need to use a z6 timing belt. keep up updated
Old Jul 29, 2009 | 12:01 PM
cns21's Avatar
the z6 timing belt is way to loose so i went to go get another timing belt i think i a vx timing belt.
Old Jul 29, 2009 | 10:17 PM
toolbox21's Avatar
the vx belt is tighter but has a diff. teeth count there for it will not allow you to get it in true time. so that could be your problem. try getting a new z6 belt that isnt stretched, ive done 3 of these mini-me's and all times ive used z6 belt
Old Jul 30, 2009 | 07:08 PM
blazzer's Avatar
+1
Old Aug 1, 2009 | 07:19 PM
luke_1's Avatar
Yea Z6 belt is the one to use.
I have done 3 or 4 mini-me s, the firing order is always a problem for me. All of my swaps have not wanted to start with what i thought was the right firing order. I would try moving plug wires around.
DelSlowmo
Mar 16, 2010 08:42 PM
B16B_coupe
Jul 9, 2006 09:06 AM
DeviousCTR
Apr 25, 2006 07:02 PM
