Heat getting inside through shifter, ebrake, bottom of feet?????
Old Jul 28, 2009 | 06:56 AM
saemoonyang's Avatar
Default Heat getting inside through shifter, ebrake, bottom of feet?????
Well I bought the car and didnt realize this problem, after the engine gets hot I can feel heat coming inside the car, through the ebrake, my feet gets dam warm sometimes even hot. So I took the center console off and it seems there is nothing that is really covering the shifter from the outside heat. Im a Nissan mech and this definetly blows me because the nissan has a rubber boot that covers the shifter and mounts the bottom to the chasssis to restrict any heat, water etc... from coming in. Called up the Honda dealer and the guy looked up for any sort of rubber boot or anything that I might be missing and he tells me theres nothing???????
Sorry for the long post.
Thanks
Old Jul 28, 2009 | 07:04 AM
90Rexx's Avatar
Default Re: Heat getting inside through shifter, ebrake, bottom of feet?????
try using rubber spray undercoating? or there is also universal heat shielding materials on the market, if its really bothering you, fix it your a tech....
Old Jul 28, 2009 | 07:06 AM
Im trying to do it the oem way, but if nothing goes I might have to create something up.
Old Jul 28, 2009 | 07:08 AM
90Rexx's Avatar
are all your exhaust heat shields intact? the B pipe should have shielding all the way back
BigDaddyRich
Oct 7, 2011 10:11 AM
pliskin679
Aug 6, 2010 04:19 AM
CompanyFlow
May 8, 2009 10:33 AM
araknis
Mar 4, 2003 04:18 AM
bigD
Aug 2, 2001 11:34 PM
