throttle body question
ok guys I have 2 questions to ask you guys... 1st what kind of throttle body is this? and If I install it on a stock intake manifold would it make my engine lag? its a 68mm
its hard to tell what that t/b is for id say b16 or something, so id try to hook it up messaure how big it is first compaired to what you got as it could be overkill
thats too big for your setup, get a stock itr throttle body for your setup, or 65mm at MOST. make sure you also port your manifold if necessary when you get the correct size TB. that 68mm should be used in cammed and ported engines...
SSGojeta
Dec 27, 2008 09:29 AM
1baddturbosi
Feb 18, 2007 07:36 PM
